Heater controls
Benfraser
Heater controls
Post by Benfraser »
Just wondering if anyone could tell me what the top slider is connected to as mine has stopped working and the air comes out of every vent and i cannot choose where it comes out, i.e windscreen, feet etc… The hot/cold slider works fine its just the blower position slider that does not. Any help?
Thanks ben….
Cliché Guevara
Re: Heater controls
Post by Cliché Guevara »
If you are in a RHD car you neet to remove the fibre panel under the glove box.With a torch look at the area kindof behind where the stereo sits.There is a black plastic lever that alters where your air gets fed to (feet screen etc) That is where it should be atached.If it is still atached to the lever then follow it upwards. it should then be clamped to the heater box.If it is still clamped then keep following it,if you can. There is another clamp about 4 inches behind the slider if it is still atached then it has either failed at the slider, or the flap inside the heater box has spat it's dummy out.
Hope this helps
Benfraser
Re: Heater controls
Post by Benfraser »
Thanks mate helps a lot i'll have a look
Ben….
