Page 1 of 2
Help: Cant turn right
Posted: 12 Aug 2013 03:59 pm
by Benfraser
So my cars developed a weird problem where when i turn right my car wants to cut out and boggs out. It smells like its over fuelling but i guess it could be loss of spark because there would be unburnt fuel? This happens when i go around a long corner or even around a small mini roundabout, the mini roundabouts are worse and the cars will inevitably cut out half way around it. When i go around longer corners it bogs and coughs but doesn't cut out. As well as this when i brake sharply and hard it does the same thing where it smells like its over fuelling and will idle low and cut out. The sharper the brake, the worse it becomes. If i am going down hill and have to brake sharply it will just die on me.
Any ideas or help appreciated,
Thanks ben….
07985607419
Re: Help: Cant turn right
Posted: 12 Aug 2013 04:51 pm
by Speedy88
Sounds like carb floats, I had a similar problem although not quite this extreme on my 1.7. Yours could well be leaking and completely sunk, causing the float chamber to fill up with fuel and leak out.
Posted: 12 Aug 2013 05:04 pm
by Benfraser
Speedy88 wrote:Sounds like carb floats, I had a similar problem although not quite this extreme on my 1.7. Yours could well be leaking and completely sunk, causing the float chamber to fill up with fuel and leak out.
What would you suggest?
Posted: 12 Aug 2013 06:45 pm
by Speedy88
You'll need to get new ones, what engine are you running? 1.7 in your signature?
Make sure the floats have sunk though, they should be buoyant in the chamber.
Posted: 12 Aug 2013 07:14 pm
by Benfraser
Speedy88 wrote:You'll need to get new ones, what engine are you running? 1.7 in your signature?
Yes it's a 1.7 and ill have a look at them tonight and see
Ben....
Posted: 12 Aug 2013 10:26 pm
Fit fuel injection, carbs never liked corners anyway
Posted: 12 Aug 2013 11:04 pm
by Benfraser
Ride_on wrote:Fit fuel injection, carbs never liked corners anyway
Thats alot of effort no?
Ben
Posted: 12 Aug 2013 11:23 pm
A bit yes, and expensive unless you can transfer something from a Renault, was joking really. I have always noticed my carb 300s bog in the corners, but the injections don't.
Posted: 12 Aug 2013 11:26 pm
by Benfraser
Bogging is one thing but to the extent that i cant go around a mini roundabout without it cutting out!
Posted: 14 Aug 2013 05:10 pm
by Benfraser
So today I took my carb apart to troubleshoot and I first off measured the float height which came up as an odd reading (I had found the exact values in the engine spec in the green books section) and then I had heard about the common problem of the floats becoming pouros and absorbing fuel thus making the float heavier and not allowing the v.alve to close all the way. So I weighed mine and it came out at 16g. I looked in the spec and saw it should weigh 6g plus or minus 1. So hopefully this should resolve the problem as this would cause it to over fuel and run rich.
New float on tomorrow and hopefully all will be well
Ben....
Posted: 14 Aug 2013 06:37 pm
by macplaxton
Why weigh it?
Shake it, shake it, shake it. You'll hear sloooshing petrol inside if it's leaky. To find out how many holes it has, boil up a pan of water (turn a gas stove off) and with some plies dip it in the hot water. Bubbles will stream out of the holes.
Also, worth a browse....
http://www.volvo300mania.com/forum-uk/v ... =39&t=9289
Posted: 14 Aug 2013 11:09 pm
Th 1.7 carb has solid/spongy floats that mac says 'cannot leak'. It not like the 1.4 with a metal hollow float.
They can absorb fuel, and I guess do not rattle.
Posted: 15 Aug 2013 01:14 am
by macplaxton
Ride_on wrote:Th 1.7 carb has solid/spongy floats
Ahh, forgot about them pesky buggers that lose their skin and soak up fuel like a sponge.
I reckon Mac should change his wording and lose the "cannot leak" mentions. It seems that ethanol may "eat" away at the skin of some types of these floats and they effectively become leaky. Okay, so they don't rattle, but a pot of water would show if they floated properly (or not) in the absence of scales. A boiling water test should still show up the problem though?
Posted: 15 Aug 2013 07:52 am
by volvodspec
Posted: 15 Aug 2013 01:40 pm
by macplaxton
^^^^ Top man for digging out some good pics.
