Ramair - Valver/Williams (F7P/F7R) Foam air filter
linkay
Post by linkay »
Ramair air filter for sale. I had this fitted to my F7P powered 340 with both a standard and reversed inlet manifold.
Car ran well with it, very quiet in normal conditions but sounded mega on full throttle with a lot of induction noise.
It has two holes in the back for the idle control valve and teh cam cover breather pipe, however these can be blocked off if not needed.
I'm after £30 posted for this.
Cheers,
Ben
89(F) 340 DL F7P - Sold :(
Clio 182
Alex Laidlaw
Re: Ramair - Valver/Williams (F7P/F7R) Foam air filter
Post by Alex Laidlaw »
Do you know if it will clear the heater box on the standard F7P manifold?
EDIT: Just looked at my car for the first time in months and realised what a daft question this is! Forgot how tight the standard manifold is to the bulkhead.
linkay
Post by linkay »
Yeah, it's pretty tight in there with the heater box in from what I remember.
You don't happen to be the same Alex from the Brookes FS team do you?
Clio 182
Alex Laidlaw
Hi Ben
Yes it is. That downpipe you made is absolutely brilliant, one bit of the car that fitted as per the CAD and didn't break despite all the abuse we gave it this year!
linkay
Post by linkay »
Haha brilliant! I'm glad all went okay.
Ben
Clio 182
