just a quickie - i replaced the bulb for 'lights on' on me dash, and its now working for the first time ever! thing is - it comes on with even side lights on - i thought it was for dipped beam only? or am i wrong??
oh and another thing - my handbreak light doesnt work - where should i look for likely broken stuff?
dash lights..
dash lights..
- Duvel78
- Website Admin
Re: dash lights..
The wire is often broken (see the red arrow...)5lab wrote:my handbreak light doesnt work - where should i look for likely broken stuff?
Concerning the lights, it's normal... A little detail is interesting: the bulb behind the switch for the lights works CONTINUOUSLY on my 1987 GLi, it's not the case with the 1984 models...
V3M for life!
V3M for life!
thanks for the info - i'll have a look.
i dont *think* that light is always on in my '86, but i'll check tonight. i wouldnt be surprised if it never comes on - the cars not been best looked after and i think little details like that might have been oft overlooked.
thanks for the help mate - i've got the light working (was that exactly that had happened). i've got to get the hazard light working (pretty sure thats a bulb as the indicators light up), and the rear heated window (which i think is cos i disconnected the strut, which i did so that the boot light would go off, i think i'll just take the bulb out...)
- foggyjames
The headlight switch is always on with the ignition - so you can find it in the dark!
If your boot light refuses to go out, its most likely a problem with the switch - have you tried operating the switch manually? Mine did this for ages, and it was due to a buckled strut mounting (long story!)
- foggyjames
It's attached to the drivers side strut. There's a sliding collar on it which is moved by the 'body' of the strut when it closes.
- foggyjames
Yeah, especially if you're using non-genuine struts with an original switch or visa-versa. I have a spare switch here I can drop in the post if you want Hugh?
