headlight switch bulb.
baron_matt
Post by baron_matt »
340 Mk3 1986
Hi
Its just a minor annoyance but the bulb has blown that illuminates the light switch, does anyone know how to access it to change the bulb?
Matt
Re: headlight switch bulb.
Whip off the instrument panel surround, draw forward and change bulb.
They'll be a couple of screws or so that hold the metal strip in at the bottom (or is it top?)
baron_matt
Hi
How do I get the panel surround off?
Do I need to remove the steering wheel?
Ta
Thinking about it further.
If you can stick your hand up behind the dash, then I think the bulb holder is just a push fit into the back of the bit that surrounds the back of the switch.
Otherwise, I think the next route, is to remove the lower and upper column switch cowlings in order to access the bottom fastners that hold the surround in place.
Will have a quick look in the morn.
Cliché Guevara
Post by Cliché Guevara »
Make sure you use a 24v bulb. :wink:
