BUGS on the board?
Duvel78
Website Admin
BUGS on the board?
Post by Duvel78 »
If you encounter a bug somewhere on the board, let me know, the list bellow will be regularly updated with your reported bugs and my solution or status.
*no access to some of the categories when logged in, access as guest OK*
Solved!
*"online" banner under the avatar instead of above*
To check
*the auto resize Mod doesn't work for some pictures*
To check
*missing threads / all my posts aren't visible on the board* DON'T PANIC! lol
True, because I'm regularly adding thousands of posts into the right categories, they have to be checked first and dispatched to the new created sections... Be patient please! :)
V3M for life!
Duvel78
Website Admin
Re: Bugs on the board? Let me know here!
Post by Duvel78 »
classicswede wrote:When logged in I can not access any of the technical sections of the forum however when not logged in I can read all of it?
Is this just short term while the forum is moved around and sorted?
S10NPH wrote:I have the same issue. Thought the forum had decided to ostracize me, so I'm glad to hear it's happening to someone else too!!!
Joris wrote:I'm having the same troubles, I can only open the Engine forum! I wanted to start topic to introduce my 360 but have no permission to do so..
360beast wrote:Same I can only enter the engine forum, but can go everywhere when not logged in.
Problem solved! Had nothing to do with wrong permissions for the normal users group, just a surprising "no role assigned" for some forum categories, so no access :-) It's now adjusted! Please check!
V3M for life!
Duvel78
Website Admin
Post by Duvel78 »
S10NPH wrote:Thanks, yes it works now (though my threads haven't made it through yet!).
Normal, as I said in another topic, I still have to check a lot of messages (thousands!) in an invisible category yet and dispatch them to all the new categories. I'm doing it regularly each day but don't expect from me to do this in 3 days time LOL :D
V3M for life!
S10NPH
Post by S10NPH »
I know, don't worry :D Thanks for all your hard work, looking forward to many more years of v3m-ing!
Duvel78
Website Admin
Post by Duvel78 »
You're welcome mate!
V3M for life!
sm4
Fixed and working great.
Re: BUGS on the board? Let me know here!
Images in signatures: Showing ok for pre-existing signatures, won't work for editing signatures.
Existing signature appearance:
signature1 by macplaxton, on Flickr
Control Panel pre-edit:
signature2 by macplaxton, on Flickr
Control Panel on preview after edit:
signature3 by macplaxton, on Flickr
Edit to add:
Possibly related: Avatar auto sizing. "It was not possible to determine the dimensions of the image"
Going into edit my avatar, image is 100px x 100px on screen. (actual image size is 120px x 100px)
Pressing "submit" with null values in the dimension boxes, produces error "It was not possible to determine the dimensions of the image".
signature4 by macplaxton, on Flickr
However, if dimensions are entered (120 x 100 in this case), image is updated fine and no error:
signature6 by macplaxton, on Flickr
120px images next to PMs too wide for template and spill over white vertical dividing line...
signature5 by macplaxton, on Flickr
Something similar occurs when view on mobile devices, or more precisely, when the browser window is reduced in width beyond a certain point:
signature7 by macplaxton, on Flickr
Duvel78
Website Admin
Post by Duvel78 »
Macplaxton, for the "It was not possible to determine the dimensions of the image", I just checked very quickly, seems to be a specific PHP parameter to be activated by the hosting (allow_url_fopen = on), they didn't activated it, there must be a reason. I added php_flag "allow_url_fopen" "On" in a .htaccess, do you see a difference? Refresh everything before!
Avatar too large for PM: true, same problem here, dimensions inside of the template to adjust, or avatar auto resize, don't know yet.
Macplaxton wrote:Something similar occurs when view on mobile devices, or more precisely, when the browser window is reduced in width beyond a certain point:
Display on mobile devices is just fine (trust me, I've tested on iPad, several tablets, phones...) The problem is when you manually ajust the window below the board width, the avatar begins to cover the separation line and in the worst case the text, that's true. Maybe I can find one solution for both avatars problems.
V3M for life!
viewforum.php?f=83
There is a solo topic at the bottom of this page. Is this meant to be possible?
or should it have automatically been placed in viewforum.php?f=90 ?
Post by MCHUDD »
Does this mean mt threads will come back?
:D :D :D :D :D :D :D :D :D :D :D
Duvel78
Website Admin
Post by Duvel78 »
macplaxton wrote:viewforum.php?f=83
Good observation, it wasn't meant to be possible, new topics have to be created inside of existing categories. I moved the topics manually and will see how to deactivate this.
V3M for life!
S10NPH
Post by S10NPH »
I know you are still trying to sort through old threads to correctly categorise them, but is it possible in the meantime just to put them somewhere temporary so that they are accessible? There are loads of old threads that I want to look at but can't.
Or is there any way someone else can help you work through them?
Duvel78
Website Admin
Post by Duvel78 »
S10NPH wrote:I know you are still trying to sort through old threads to correctly categorise them, but is it possible in the meantime just to put them somewhere temporary so that they are accessible? There are loads of old threads that I want to look at but can't.
Please PM me the threads with subjects in your mind that you would like to see again, I just did the same with Helldriver, I'll treat them prioritarily!
classicswede wrote:Or is there any way someone else can help you work through them?
I really appreciate your offer Dai! I'll evaluate the progress in a couple of weeks and if I still have a ton of messages to check & categorise, we could imagine splitting the work, I'll see. Having said that, some important changes in my life shortly will probably affect the reduced time I already can spend for Volvo's :? , more in the introduction section :mrgreen:
V3M for life!
It would be nice to have the remaining topics moved to correct sections at some point
