Tourque tube
Tourque tube
Post by MCHUDD »
Hi lads.
Does anyone know how to separate the Tourque tube from the Gear box of a 360?
sm69 sm69 sm69 sm69 sm69 sm69 sm69 sm69 sm69 sm69 sm69 sm69 sm69
Joris
Re: Tourque tube
Post by Joris »
you first need to unscrew the two bolts under the rubber thingies in the torquetube, then the link between the axle and gearbox is disconnected! then you need to unbolt the four imbusbolts holding the torquetube to the gearbox!
might need to losen the gear linkage
Re: Tourque tube
Take one of the bolts right out of the sleeve clamp, loosening is not enough, the bolt shaft stops it from separating.
