bonnet hinge plastic bushes
The 2 plastic inserts for the main hinge and the 4 small ones for pins, failing that the metal parts they come in. They can be very brittle and break when removed.
Re: bonnet hinge plastic bushes
The main hinge bushes are down by the headlights.
The small hinge bushes are in the bracket attached to the bonnet
The spring rod bushed are also marked with a line, mine only has 1 which seems odd.
Bushes marked with a yellow line
Brackets that contain the bushes circled, best to send these as they tend to break when removed (except the spring rod bush as it is held in with spring pressure only)
- Attachments
- Bonnet hinge mechanism
- Hinge bushes.JPG (57.82 KiB) Viewed 38023 times
- Main hinge plate
- hinge bush.jpg (131.94 KiB) Viewed 38023 times
i got a phonecall from a friendly n'irish posty saying there didnt appear to be anyone at home. having told him to find somewhere safe and that i was happy for it to be left, he said 'ill go and have a look', hung up and didnt call back .... #
did you get it??
did you get it??
