kloppen
Posts: 20 Joined: 12 Feb 2005 06:23 pm
Post
by kloppen » 11 Aug 2005 08:48 am
I was wondering how to adjust the idle speed on my B200K (86 mod)
I cant fint any skrew....
Can it be in this phote?
Help Please...!!
antiekeradio
Posts: 697 Joined: 04 Jan 2004 10:53 am
Post
by antiekeradio » 11 Aug 2005 09:40 am
nope, lower, other side of carb
kloppen
Post
by kloppen » 17 Aug 2005 01:20 pm
Where, can you show me?
antiekeradio
Post
by antiekeradio » 17 Aug 2005 04:23 pm
arrow 2, are you pointing to the white disc section, or something that is behind that????
could well be there!!! it should be the screw that defines the (rotary) position of the white plastic pulley with no throttle.
it could also be that this setting is done through the cable connection (just outside your pic, right side) but normally such a setting is not ideal.
Greetings Wouter
kloppen
Post
by kloppen » 18 Aug 2005 09:08 pm
I dont see it, can you show it with an arrow please?
Posts: 5805 Joined: 23 Jul 2004 03:50 am
Post
by jtbo » 18 Aug 2005 09:12 pm
Citroen ZX Dturbo -97 -daily-
kloppen
Post
by kloppen » 18 Aug 2005 09:20 pm
Are you sure?
Thank you...
Post
by jtbo » 18 Aug 2005 09:26 pm
Yes I'm sure, that adjusts position of throttle linkage and idle speed. Some older model had different location for idle speed screw, but I'm not sure if it was used in 300 serie at all.
antiekeradio
Post
by antiekeradio » 18 Aug 2005 10:22 pm
THAT's THE ONE!!!
100% sure.
