B21ET
tralla44
B21ET
Post by tralla44 »
Hey guys, i will have block B21ET head from B23FT and wires too from B23FT. Will it crankshaft sensor fit from B19A from carburator?
Please someone help me
Ride to Live
Live to Ride
Re: B21ET
The 360 crank sensor fits to the 360 bell housing, not the block, and I think B19 360 did not use a crank position sensor. It was either breaker points or hall effect trigger in the distributor.
You need to either modify the 360 bell housing to fit the block mounted bracket or get a B200 bell housing (I guess these are different, unless the B19 bell housing has it).
I'd prefer the 360 mounting rather than weakening the B19 bell housing. Other options are to make your own mounting by using a precise insert to get the height, or to make a custom pickup somewhere else on the engine.
tralla44
Re: B21ET
Post by tralla44 »
Mhm, but if i use B21ET flywheel and b23Ft cranksensor? Mhm but B21ET crank sensor have too on bell housing?
Ride to Live
Live to Ride
tralla44
Re: B21ET
Post by tralla44 »
Maybe i need flywheel from B21ET but cluch kit from B19A
Ride to Live
Live to Ride
Re: B21ET
You can use various clutch pressure plates, different ones give different holding pressure. You need a friction disk that matches the 360 drive shaft. The 360 disk is only 215mm but the rest of the parts are 228mm, so the Audi disk is 228mm and fits the 360, or any B2xx solid flywheel.
All solid flywheel 200/700/900/360 use similar clutch cover, but the 360 one is a bit flatter at the edge to fit the bell housing. You can just grind down the edge a little for one designed for the bigger bell housing.
I'm not sure the crank sensor matters very much but you can make any sensor fit.
tralla44
Re: B21ET
Post by tralla44 »
Ride_on wrote:You can use various clutch pressure plates, different ones give different holding pressure. You need a friction disk that matches the 360 drive shaft. The 360 disk is only 215mm but the rest of the parts are 228mm, so the Audi disk is 228mm and fits the 360, or any B2xx solid flywheel.
Thanks for anserw mate. What place on flywheel need.to cut to be faster engine.. ?
I don, known the real name
Ride to Live
Live to Ride
tralla44
Re: B21ET
Post by tralla44 »
From what audi is this cluch?
Ride to Live
Live to Ride
tralla44
Re: B21ET
Post by tralla44 »
Another quastion
I have this flywheel
It,s from B19A
But sensot will goes from kind of this flywheel
B23FT
Will crancksensor working??
Some friend told me he have T5 in his Volvo 760.
He has the same issues and hi was in internet reading there need only swich wires in ither place.
And than it will work.
So my quastin is Will it work ?
And that,s is a true what hi was told me ?
Ride to Live
Live to Ride
tralla44
Re: B21ET
Post by tralla44 »
New clutch bought from Audi 80 B2 quattro
Thnx mate
Ride to Live
Live to Ride
Re: B21ET
I just ground down the corners at the edge of the clutch.
Sach 763 modification
The Audi disk link was in the ebay collection link on the project thread
http://www.ebay.co.uk/itm/CLUTCH-DISC-A ... 6016.l4276
I have seen that flywheel and I think it needs a different computer system than the Bosch EZK, I'm not sure yet how critical the pickup is.
Mine is a 940 solid flywheel (almost the same as the 360) for Bosch EZK ignition.
