Anti-roll bar mounting bar needed for 360.
Post by bogbasic »
I don't know what its called but I need the bar which goes under the front of the engine on a 360 and it is bolted onto the chassis and onto the anti-roll bar, I think. On the 360 I don't think it carries any weight whereas on the 340, it has engine mountings on it. Some pics will say more....
There isn't much left of mine on one side - I think its cos a welder used it as a jacking point once and it went a bit crunch...
thododd
Re: Anti-roll bar mounting bar needed for 360.
Post by thododd »
oooh, thats pretty beefed!!
ive got a 340 front crossmember
here it is next to my 360s
just needs the front engine mount brackets whipping off with your preferred cutting tool and Robert's your mothers brother
Post by bogbasic »
Hello,
Wicked work - that looks in good nick and it'll save messing about with scrappies on the phone so how much do I owe you? Also, if I leave the 340 mountings on, do you happen to know if it will still fit?? If they don't get in the way, might as well leave them on ;-0
thododd
Post by thododd »
Not sure if itll fit with the extra bracketry in place .... i had ample opportunity to try but never bothered :roll:
Drop me a pm with some postage details and ill get a quote and go from there
Post by bogbasic »
Thanks for this, very much - arrived yesterday :-3
Logan360
Post by Logan360 »
From what I know of the 360 the brackets for 340 will probably need to come off, if not it will be quite close to the sump and may contact constantly or over bumps.
Own:
86 & 89 360GLT
00 S80
01 Subaru Lancaster 6
02 Subaru GT30
Owned
thododd
Post by thododd »
The 340 item does actually stand a touch taller (as can be seen in the pictures) so it should offer a bit more clearance around the sump
Glad it got to you ok
