1.7 crankshaft bearing sizes
Posted: 17 Nov 2015 10:53 pm
Hi guys, need little advice on oversized bearings for the crankshaft of 1.7
i'm rebuilding my engine, is there only one oversize kind of bearings?
or 30887704 is std size and there are 3287717 and 3344542 as oversize for the 4 bearings, other than main?
on the picture these are parts n11 and 12. And 3 types of oversized thrust bearing (additionally to std size)
Are there any renault catalogs i can buy bearing from? Is it f2n, f3n renault 1/7 engine?
The engine i'm currently trying to rebuild is 1.7 from 400 series (6 bolts on valve cover) but still have original 1.7 from 340 with metal timing cover.
11 3287717 I.DIA 47.75 mm, REPL 1 PCS 30887704.
3344542 I.DIA 48 mm, REPL 1 PCS 30887704., (3287718)
30887704
12 30623800 I.DIA 54.55mm
3486204 I.DIA 54.80 mm
13 3287713 THK 2.30 mm
3287714 THK 2.35 mm
3287715 THK 2.40 mm
3287716 THK 2.45mm
30887704
3287714 THK 2.35 mm
3287715 THK 2.40 mm
3287716 THK 2.45mm
