Airbox thermostat replacement on early models
ralf850gle
Post by ralf850gle »
Hi all,
while I was derusting my airbox on a '80 343 1.4 with variomatic, I discovered, that the warm air intake was full open
at room temperature.
Reason is this little thermostat thing
which is now at room temperature. At this temp it should look like this
So this part is dead... and replacement not available.
So I ordered the airbox thermostat for 200/700/900 models. This thermostat looks quite similar and has the same
diameter, but is 0,3" too long.
To put it into work I had to dismantle the plastic holder and cut the spring to fit.
Now it looks like this:
I tested the solution and it works well.
Hope this helps others 343 users....
Regards
Ralf
Re: Airbox thermostat replacement on early models
Post by bogbasic »
Awesome work. Early it up.
