I am at present cleaning up a transaxle from a 360 GLT I picked up recently. Before I start throwing too much solvent etc about I am curious to know what the little rectangle shaped orifice is on the side of the overdrive housing.
See picture below.
Thanks to those who have take the time to reply. It appears I will need to investigate this and see what it is about.
That said there is the need for some gaskets to reassemble the transaxle.
I see that they are still available but note there is some duplication.
For example the transmission to clutch housing gasket. There are two listed . Both appear the same but have different prices.
I see there is a link to enable the insertion of the 17 digit model number. I do not have that number so can anyone explain the differences in these two gaskets and the others where there is duplication like the side cover and the other clutch housing gasket. I trust this make sense.
Cheers, Fred http://www.skandix.de/en/spare-parts/dr ... ssion/909/
