360 turbo conversion auto donor car
loz1985
Post by loz1985 »
Hi all,
I'm just about to start my 360 turbo conversion. I would like to go down the route of the b230ft conversion but can only find 940 2.3 turbo automatic in my budget.
Can you use an automatic 940 as a donor or will it complicate the wiring or anything else? Was planning on using my current 360 box/diff and bell.
Thanks
360beast
Re: 360 turbo conversion auto donor car
Post by 360beast »
You just need a manual flywheel is all, wiring will be the same and the benefit of the auto is it has an oil cooler for the gearbox oil which you could use for the engine oil instead on the 360.
loz1985
Post by loz1985 »
Thanks for your advice. I will go and buy the auto I have found then.
