Volvo 440 6spoke alloy 15" (One of)
- 340GLT
Hi guys i'm looking at getting a 5th alloy to squeeze under the bonnet. Only need the one so if anyone has one ior knows of one in a local scrappy please let me know. Preferably with centre cap, tyre not needed!!!
Cheers Adam
Cheers Adam
- petefarrell360
- 340GLT
Yeh i've just spoke to Salvo Group who have a set on there and they said they have a few odd ones about £35 delivered but considering i only paid £83.50 all in with 4 good tyres i thought that was a bit steep!!! lol
Cheers Adam
Cheers Adam
- petefarrell360
- 340GLT
Well when i bought the full set they were cheap because they were listed as vovlo alloys not volvo!!! The advantage went my way and disadvantage to the seller!!!!
Cheers Adam
Cheers Adam
You cutting hole for the wheel or mounting it underneath? and whats the advantage of the '60 tank, it's not much bigger (though I was tempted to run both, apart from the stupid weight I'd carry)
- foggyjames
It is quite a lot bigger...isn't it? Good luck on the metalwork involved in cutting the boot floor
Remember you can always fit an electric pump to the 340 tank...or quite possibly not use a pump back there at all.
I can collect stuff from Salvo when I'm up in Derby...and bring it to a meet?
- 340GLT
Sounds good when you in Derby? The only thing i am afetr is the alloy wheel from a 440!! They quoted me £35 summut delivered minus tire so i'm reckoning about £10 less would be good but £20 would be ideal!!! Dont mind paying more for a mint one!!!
As for the 60 tank its a 57litre as apposed to the 45 in the 340!!
Should be straight forward to do the floor and the tank will bolt straight in!!
Cheers Adam
Cheers Adam
- foggyjames
Ok..I'm sure we can work something out
Surely the boot floor is welded?
- 340GLT
Yep but then again, so are the sills!!!! And under the boot mat you can get away with a slightly different colour!!! And the boot floor goes between chassis legs so its not strictly structural!!!foggyjames wrote: Surely the boot floor is welded?
Cheers Adam
- foggyjames
Sorry...I just mis-read your original post...I thought you meant you could bolt in the boot floor!!
