Lowering anyone????
Lowering anyone????
Post by 340GLT »
Well these are the lowering blocks i made at college. I havent got round to fitting them yet as i am getting some front springs from Dai!!!
Anyways they are 40mm!!
What you reckon guys?
Cheers Adam
bodejodel
Post by bodejodel »
If they fit and you are happy with them I might be interested...
Jeroen
Post by 340GLT »
I suppose a small production run, maybe possible!!! :wink:
Cheers Adam
bodejodel
Post by bodejodel »
I guess the small hole is where the pin on the leaf goes in and the big holes are for weight saving?
Is it aluminum or steel? (looks like steel...)
Jeroen
Post by 340GLT »
Yeh that is correct mate. They are steel, but could be made in ally to make them super light!!! i made them from steel as i had it and it didnt cost me anything but they may get changed at some point!!!
Cheers Adam
robbieg
Post by robbieg »
u fancy making a 60mm set?
Post by 340GLT »
The only problem with doing a 60mm set is trying to lower the front the same amount!!! I'm gonna struggle getting the car to sit level doing a 40mm!!! But when i'm back at college i could prob make a set up!!
Cheers Adam
robbieg
Post by robbieg »
could always stick a bag of sand under the bonnet?
Erm where? Someone decided it was a good idea to put an engine under there ;)
Post by redline »
sounds like its sm69 HACKSAW TIME sm69
yeehaw
Take the hacksaw in your hand sm89
cut a coil (just one strand ) sm89
drop your car down off the jack sm89
your car is lowered ,just like that sm67
robbieg
Post by robbieg »
seriously im thinking about it, take the spare wheel out, and stick a bag of cement in there, spare wheels are for pussys anyway
RandomHero
Post by RandomHero »
Walking or taking public transport home when you have a flat tire is for pussies :lol:
bodejodel
Post by bodejodel »
I believe the coil is still under tension when the car is jacked up...? could dost you a couple of fingers when you start cutting a tensioned coil...
Jeroen
"Warning, this Redline Rap may cost fingers"
:lol:
robbieg wrote:u fancy making a 60mm set?
What is your current ride height
(see pic)
60mm at the front is possible from standard but most 300' have sagged almost that much!!
Oh Adam are going to fit locating pins in your blocks as they are needed to locate the srings.
