Happy
Happy
Post by 990 »
I have just been offered a new crossmember for my 360GL :D
How hard is it too fit?, I have 12 days until my free retest runs out :360:
Volvo 360 -- Small Car - BIG Ideas
E990 UBA Volvo 360GL - Vanised
D133 OBU Volvo 340GL - Died
F330 FWB Volvo 360GLT - She Runs :)
GJ53 GPF Volvo S60 - Daily
Post by redline »
pleased to here it, good luck with the work
Should be an easy days job. You will need to disconect the steering rack(5mm hex key if same as 340) wishbones and then there are 3 or 4 bolts each side. I know the 340 engine mounts bolt to it but not sure how the 360 fit on.
I hope you fix it now so I dont have to find room for another car.
990
Post by 990 »
The 360 mounts to it pretty much the same way...
If you are going to be fitting it on your drive make sure you support the car on some wood to spread the load.
When I did my engine swap I held the car up on axle stands the end result was a dent in the cassis rail on both sides.
990
Post by 990 »
Thank's for that, i'll be doing it in the garage but it good to know - cheers :P
990
Post by 990 »
Thinking about it i'll take some photos so if anyone else has a problem we can put up a visual reference. May as well make use of it while it's being done eh :mrgreen:
Yeh go for it take pictures of all the bolts etc you have to remove and do a spep by step write up. It would be a very good referance for other ppl to use :D
990
Post by 990 »
Ok, hmmm
A step by step write up :?
Ok here goes page 1 of 500 :mrgreen:
Damir130
Post by Damir130 »
Its quite a tedious job. The crossmember can be removed and refitted with everything else on the car, but the bolts of the steering rack are very difficult to get at. Spent something like an hour of wrenching on them. Other then that its pretty straightforward, remember to replace all bushing wherever you see them.
Scuderia Rollator: Racing fridges and tractors
1988 Volvo 360 trackbeater and money eater
1983 Toyota AE86 GT-coupe - moneypit numbero dos
1985 Toyota AE86 trueno - drift only
1972 Toyota Corolla KE25 coupe
990
Post by 990 »
Any hints on which bushes I am gonna see?. Also what type did you replace them with
Its only the wishbone and tie bar bushes you are likely to disturb. I can supply poly ones if you want them.
990
Post by 990 »
Now that is VERY tempting - how much sm15
The wishbone to crossmember bushes ar £25 the pair and the tie bar ones ar £20 the set.
990
Post by 990 »
Sounds good to me, the Crossmember arrives on Tuesday :!:
How pay? send me a pm :lol:
