Prop shaft new.
Posted: 07 May 2021 10:25 am
by sadican-1668
clean shaft. It was very nice. no vibration. no vibration. no sound. no balance. it's number ten. engineering wonder. I would recommend it to everyone. Turkish master. Turkish technician. I have been using it for months, no problem.
Re: Prop shaft new.
Posted: 09 May 2021 07:01 am
by bogbasic
Wow! That looks really cool! How do the fittings compare with the standard shaft which has allen key bolts, I think. How much do you charge?
Regards, Jon.C.
Re: Prop shaft new.
Posted: 09 May 2021 07:21 am
by sadican-1668
I am very pleased. I got $ 300.
Re: Prop shaft new.
Posted: 09 May 2021 04:35 pm
by bogbasic
Hello again, thank you for your reply. Is that a 4-speed or 5-speed? I think the automatic has the smallest shaft. Do you have a website with some more photos and contact details?
I might be looking for a 5-speed propshaft... actually I am looking to get an interesting spare one. Would you need a broken propshaft as part-exchange? I do not have one because I have never broken one - I don't do drag racing, or other monstrosities....
https://www.youtube.com/watch?v=nqqZ28m8uCo
Peace and safety, brother ;-0
I guess someone would sell me a broken one, if they've not all gone in the skip by now!!
Cheers, Jon.C.
Re: Prop shaft new.
Posted: 09 May 2021 09:22 pm
by sadican-1668
used the ends of my old shaft. the rest produced from scratch. 5 speed manual car. I've never had any problems so far. the car is driving very well. I'd like to help you, but I need milled ends of the shaft.
Re: Prop shaft new.
Posted: 09 May 2021 09:44 pm
by bogbasic
Cool, I will try to get a broken propshaft!
Re: Prop shaft new.
Posted: 12 May 2021 08:01 pm
by bogbasic
Hello Sadican-1668
I am trying to get a propshaft. Things are happening, so do please stay in touch.
Cheers, Jon.C.
P.S. you said the photo is number 10. Sounds like you have made a few of these?
Re: Prop shaft new.
Posted: 26 Aug 2021 02:46 pm
by bogbasic
Re: Prop shaft new.
Posted: 27 Aug 2021 02:14 pm
by bogbasic
Call to Propshaft Services Feltham: "No, we don't repair 'em". Can't argue with that. ;-0
A search for Reco-Prop Luton (recommended in one of the threads) shows they have gone bust.
Manifold titters abound.
Re: Prop shaft new.
Posted: 29 Aug 2021 01:48 am
by bogbasic
My guts are howling with belly-ache, but my guardian angel is looking over me and here's the latest.
Thought: what's under those riveted panels? Is there a hole in the aluminium tube that would allow access to the back of the coupling?
So hand-drilled out the rivets and, blast, no hole! They must be there to balance the bolts.
Used a parallel pin punch to tap out the rivet stubs.
Next challenge was to remove the stubs from the tube. Water and shaking it up and down seems to have got them out.
Despite appearances, did try to research some of this before, but came up with nothing.
Re: Prop shaft new.
Posted: 30 Aug 2021 12:12 am
by bogbasic
More homework shows that the manual prop shaft is 121 cm long, 7 cm wide and has the splined coupling split in 3 places 120 degrees apart, as shown above, to allow the clamp to tighten it.
In contrast the auto prop shaft is 116 cm long, 6 cm wide, has, as wisely pointed out in another thread, uncut splines:
and no room for a clamp! So the auto prop shaft is skinnier and the ends look more exagerated!
The above diameters are for the main part of the tube,
i.e. not the wider ends. The lengths include the projecting splined bits, well, at least for the manual shaft.
You also get some more useful hits by googling for "intermediate shaft" rather than "prop shaft"!
Re: Prop shaft new.
Posted: 30 Oct 2021 06:09 pm
by Alexfbuk
hi, if required I have 2 broken props for someone to use the ends of or weld 2 together, I don't know if pms work here so
alexjseaton@gmail.com would be better if of any use
Re: Prop shaft new.
Posted: 31 Oct 2021 03:07 pm
by bogbasic
Cool. I will email you. I actually have 5 now but still interested. These things become a bit of an obsession / ritual that's hard to break out of but still blooming interested. People have wanted anything between about £15 and £30 for them. Ta jc
Re: Prop shaft new.
Posted: 07 May 2022 07:09 pm
by bogbasic
Re: Prop shaft new.
Posted: 08 May 2022 10:26 pm
by TasMan
Some really interesting development work there....!
Hope it all works out. Cheers Dave
