Steering boss help needed
Just got the steering boss off Adam, tried to fit it but either the boss is too long or the threaded bolt is too short?? Has anyone else tried fitting an aftermarket wheel and had the same problem? Obviously I can saw the end off the boss as it isnt threaded for the last 2cm's anyway which would give me enough thread to get the nut on but its a bit of a bodge!
Ali
Ali
Are you useing the nut that came with the boss as the original one will not fit.
- 340GLT
Hmm thats a strange one Mate i do remember seeing the nut that came with the boss is different though!! Have you tried that? As Dai said its worth a try!! If not do you know anyone that can machine the bottom of the boss off, as that will be your best bet!!! As long as it bolts on flush and is safely on the spline it will be fine. Remember my boss is a modified 440 oner and i have had no probs!!! If you do have any more probs, you can have your money back mate!!!
Cheers Adam
Cheers Adam
Hmmm just found a problem if i cut the end off then the boss will slide on further but then less than half the splines will mesh, the only way therefore would be to cut out about 1cm in the middle of the boss and re-weld it together so that the splines end up in the right place! Does anyone know if there were different boss's for different years? The box just says 300 series 79 onwards, Adam can you remember the name of the ebay seller as I may try asking if he has any others,
Ali
Ali
- 340GLT
No i dont mate but i believe Mick may have purchased ferom the same bloke!! I know he had loads of the bosses!!! If it wasnt mick i'm sure someone at the Milton Keynes meet was talking about it, as i had the boss kit in the boot of my car!!!
Cheers Adam
Cheers Adam
I'm sure my boss is marked the same and it does fit ok.
Are you going to the next meet? as I could bring my spare boss with me and see if that fits ok.
- 340GLT
Looking at that pic again Ali does that spring compress when you push the boss on? If so you could do with someone slipping the nut on whilst pushing the boss in? Would that work?
Cheers Adam
Cheers Adam
Nah I can get a tiny bit of movement on the spring but when I put the original wheel on the spring doesnt need to be compressed so i'm pretty sure its not meant to, even then there wouldn't be enough travel to get the nut on, i'm pretty sure its not designed to fit but need to contact that ebay seller to see if there were different models as the astrali website is down at the moment, anyone else remember the guys ebay name?
Ali
Ali
