Final drive O-ring dimensions
DrMuller
Post by DrMuller »
Just posting this for future reference if anyone runs into the same leaky final drive issue as I did.
The final drive on my 5-geared 360 1985 leaked oil from the drive shafts, there is a radial oil seal ¨
OEM part number: 3266644-8
still available online: https://www.volvo340onderdelen.nl/en/sh ... 29632.html
and O-ring that I found impossible to find. SO I measured the part and found a replacement.
OEM part number: 3292523-2
The dimensions are 97(inner diameter)x3(thickness) [mm] and can be replaced by a standard NBR O-ring like https://www.kullager.se/o-ring-97x3-nbr
Re: Final drive O-ring dimensions
Thank you for sharing the info!
TasMan
Post by TasMan »
Very useful, thanks for that !
1987 360 GLT
