what do you want????
cam740
Post by cam740 »
a good mate of mine Ash Davies has a business that he runs in his spare time called DVS (Davies Volvo Sport) that has largely dealt with the 240's and later model vovlo's!
Now that he has access to a 360 to play with (Mine :lol: :lol: ) we are looking at doing various upgrades for the 360s - what kinda stuff would you guys be interested in????
Now bear in mind we are in OZ so PLEASE dont list twin turbo V8s as a requests (FOGGY!!!! :D )
we will def be looking at doing strut braces - what else??
his website show's teh range of stuff he has on offer at teh moment
http://members.optusnet.com.au/ashdavies/dvs/
thanks guys and girls!
Post by 340GLT »
Improvements to suspension, maybe a rear anti roll bar?
Cheers Adam
Fuse
Post by Fuse »
Rear anti-roll bar, watt-link and http://www.volvo300mania.com/forum-uk/v ... -f1828.htm little improvements like that on to the suspension. Rear anti-roll bar and watt-link are those what I would be most interested to see pics of. :P
cam740
Post by cam740 »
anyone else want anything???
Ronnie
Post by Ronnie »
LSD!
Maybe an adaptation of a rwd Quaife LSD or some other off-the-shelf unit?
http://www.filterfeeder.eu
daffodil
Post by daffodil »
how about having a gearbox straight onto the engine....then you would have a proper propshaft and plenty of axles to chose from including disc brakes at the rear
340_singh
Post by 340_singh »
LSD would be good, if it fits the 340 as well.... :P
strut brace for the front? and rear?
anti roll bars etc.
suspension kit as the handling on these things is pants! :cry:
I have to disagree with that with a few simple mods you have a massive improvment in handling
I also disagree now - change your shocks, it'll make a massive difference. Also, Dai's suspension upgrades seem to work a treat :D
huskyracer
Post by huskyracer »
stock car handling is pants, the body roll is enough to make you sea sick, but ultimately, it grips well an is fairly progressive on the limmit, new shocks do help massively, and dai's bushes work wonders, I also have PI front springs with one coil cut off, dai's lowering blocks and roll bar droplinks and ultra rare koni adjustables all round which have transformed it but it still has a bit much body roll, someone needs to make a stiffer front roll bar....
The front antiroll bar is my next project. I intend to make it 25mm, in the 340 style as this can be made to fit any 300.
cam740
Post by cam740 »
sorry guys and girls i'm away in Thailand on honeymoon at the moment but will be checking in periodically so please keep the idea's coming!!
The one thing that would be worth doing is and IRS set up. The drive shafts are spot on to take it. That would be the ultamate set up.
Fuse
Post by Fuse »
daffodil wrote:how about having a gearbox straight onto the engine....then you would have a proper propshaft and plenty of axles to chose from including disc brakes at the rear
Nah.. I don't see why you would want to do that in a street car because then you would ruin the one good thing in 360 compared to 240. Might as well start building a 240 if you want gearbox at front. :P If I would need drivetrain which would handle more power than the stock one does I would start looking other vehicles which had trans-axle system. Some Alfas had it. Porsches with front mounted engines have trans axle too and of course Corvette. :P More work though than cutting the chassis and fitting the gearbox in front and propbably way more expensive but then again it would be kinda exotic. ;) In rally use I understand why one would like to put gearbox in front etc... because it's much more cheaper and if something goes wrong parts doesn't cost much but in a project car I would do something more exotic. :P
volvorsport
Post by volvorsport »
crikes , ive built all my own suspension links for my kit car , i even had drawings for the rear suspension on a 360 , yet nobody cares !!
