Alloys and caliper clearance
Carl
Post by Carl »
Whats the general consensus on fitting alloys over uprated front brake calipers? I know thats a bit of an ambiguous question, but lets say I've managed to fit a set of vented brakes on the front of the 360 (assume disc diamter size is more or less the same), do you think a set of 5.5J14 alloys would fit? I know someone on here had a vented setup (cant remember who though) - which alloys were used with that?
After talking to some 480 owners, whilst I was having my brief stint owning one last month, they reckoned the 5.5J14 alloys would not clear the calipers, but the 6J14 ones would. But I think the 360 has a bigger offset on the hub so that possibly wouldnt be a problem. Am I making any sense?
Basically I'm thinking of putting a bid in for the old 360GLT alloys on ebay, but dont want to buy them if they're not gonna fit!
Any input appreciated!
Carl
But previously:
1988 Volvo 360GLT
1988 Volvo 360GLT
1984 Volvo 340DL
www.carlgibbs.com/gallery
Chris had the GLT with the vented setup... I may also have some 6x14" rims for sale from my black car...
Post by 340GLT »
Put it this way mate when done i will have 280mm vented disks and Impreza turbo 2pot calipers and will fit inside 15" 400 alloys!!
So i cant see why you would have any probs!!
Cheers Adam
Post by petefarrell360 »
Indeed, Chris was running stock Mk3 rims on Beast, and those that Steve has are very open, so cooling would be good!
Carl
Post by Carl »
Steve, that would be ideal! Let me know if you decide to get rid of them!
Adam, that sounds like an amazing feat! I'd definately be interested in learning more :)
Carl
But previously:
1988 Volvo 360GLT
1988 Volvo 360GLT
1984 Volvo 340DL
Post by 340GLT »
well it will definately be finished and on the car as its a colege project!!
It also definately has to be done for Easter!! So Fingers crossed!! The rear will also be discs and 2wd cossie calipers!!
Cheers Adam
Carl
Post by Carl »
Pete, that's why I like the look of the alloys on ebay - they're a bit more open, and only a few miles down the road (and look pretty cool!). But 15s would give me more options for future upgrades
Carl
But previously:
1988 Volvo 360GLT
1988 Volvo 360GLT
1984 Volvo 340DL
Carl
Post by Carl »
Nice one! Good luck with it all then!
Rears sound like too much hard work ;) but it would be interesting to see the results. You're gonna have one well sorted car by the end of it!
Carl
But previously:
1988 Volvo 360GLT
1988 Volvo 360GLT
1984 Volvo 340DL
I've only got a small bit of info from the vented set-up mate, it was running on standard calipers, but vented discs (pictures on my site if the uni has gaffered it back together yet...
yup, they have: http://www.ecs.soton.ac.uk/~clc202/brakes/index.htm
Only three pics I'm afraid)
I need to check to see whether I b*ggered my pads or discs last thursday
girlracer
Post by girlracer »
The calipers sit inside the wheel so the wheel width should not make a difference. The only possible reason I can think of that there is more material thickness. Looking at my wheels and calipers there is plenty of clearance.
Vicky
:wink:
