mintex pads
mintex pads
Anybody used Mintex pads?Got mesel' some coming off eblag might stop that pedal travel I'm gettin whilst goonin about.Cookin in less than 10 mile
Not tried Mintex, but they have a good rep - they sponsor a Rally too!
I had lots of pedal travel - it was the master cylinder. The seals in it perish which means you have to pump the brake pedal to maintain pressure in the system. Not fun. Rear cylinders were dodgey too (a common problem apparently).
You're cooking because your brake fluid is heavily contaminated with air and possibly other crap which lowers the boiling point.
You need to find out where the leaks in your system are. Probably mc and/or rear cylinders. Fix it. Bleed out all the old brake fluid. Fill with fresh stuff
The pads are unlikely to really make a difference in this scenario...
- foggyjames
I've only ever had fade due to old fluid.
Re: mintex pads
Is it the M1144 variety? If so, I love em!!!
Carl
But previously:
1988 Volvo 360GLT
1988 Volvo 360GLT
1984 Volvo 340DL
www.carlgibbs.com/gallery
But previously:
1988 Volvo 360GLT
1988 Volvo 360GLT
1984 Volvo 340DL
The brakes on my black car (with Mintex pads as fitted by Carl) certainly seem stronger than the ones on my saloon. But there are other variables such as old fluid to take into account, so I'm not sure whether it was just the pads making a difference!
- foggyjames
Something didn't smell good, but hot brakes smell bad even if you don't boil the fluid.
First step with the brakes is to go new allround. I've fitted new rear cyl's shoes pads and disks coupled with new fluid and they are spot on.
I'm sure they will cook with very hard use but new on normal fast road conditions.
classicswede wrote:First step with the brakes is to go new allround. I've fitted new rear cyl's shoes pads and disks coupled with new fluid and they are spot on.
Your spot on,but, I'm lazy so I'll try the pads when they arrive and let yu know
