The engine now.... Wich to go for?
340cbr
Post by 340cbr »
After the suspension I'm gonna made something to raise the power a little bit in my 340 1.7 :lol:
Now it has the B172K with a 440GL Solex carburator. It's not bad but I wan't more :lol:
After talk with my associate in this project car, we have some options like:
1. Not swaping the engine:
option 1.1 - Change the head to a 440 GLT one, raising the compression ratio to 10.5:1
option 1.2 - Turbocharge this motor (low boost pressure)
2. Swaping the engine...
option 2.1 - to a complete B18FT from a 400 Turbo
option 2.2 - to a Clio/19 16v F16 Renault motor
Every of it have advantages and disadvantages.
What's your opinion? Wich is the best to go for? Advantages?
| 92' 965 Turbo 16v | B204FT - 190hp |
Had: 90' 340 GL + Turbo | B18 FT | Koni's | Alpina White |
340 Nate
Post by 340 Nate »
i'd go for the renault F16 engine as ive been thinking of getting one to strip, clean and add forged pistons etc, prolly add a turbo kit to it if all things works out right in the engine bay?
Nate
Wiktor
Post by Wiktor »
Hi 340cbr.
I've got B172K too, and I have a few questions :)
Did you change only carburator? Or meaby carburator with inlet manifold.
And what about exhaust manifold?
Sorry for my english... I'm not good at it ;)
B172K Power ;)
340 ST27584 B14.3E from 15.VI.2004 to 01.II.2005
Sold
340 ST15145 B172K from 10.II.2005 to 18.02.2006
Damaged
340 ST34056 B172K from 10.III.2005
340cbr
Post by 340cbr »
Only the carb.
The exhaust manifold is different in the 440, but I don't think is that easy to put it in the 340 cause of the motor position...
But the carb gives you some difference :lol:
5lab
Post by 5lab »
put the 16v engine in. most powerful, easy to tune..
340 Nate
Post by 340 Nate »
just wondering (again :P ) if the engine mounts on the F16 are same as the B172K?, any chopping with manifolds aswell trying to fit it in or would it be a custom exhaust?
Nate
volvorsport
Post by volvorsport »
i researched this in the late 90s .
basically the 16v will fit the bellhousing , but you cant be sure it has all the holes drilled for the rear drive configuration .
unsure if the head will fit straight over onto a 1.7 block , since it fits the 1.8 which is an overbored 1.7
if it did you would fly cut the turbo pistons for the valves , and have a low compression for turbocharging .
there may be issues with manifolding not being able to fit since it goes to a crossflow design .
if you see the pics of the forged rods ive shown , these would be ideal for the conversion , or a high power turbo lump .
i met a guy (well i worked with him for two weeks) who used to work at meccachrome and built a few 16v renaults , with diesel rods and 2 litre pistons , since they are huge apparently . the next mod would be some cams , and a remap would unleash 30 hp . over a std engine , not to mention the 2 litre version if you were going to build it .
SJS has installed 16-valve 2,5l penta engine:
http://koti.mbnet.fi/fredrikr/Volvo%20340DL/images/
The big problem with the 16v renault engine is the the air intake goes direct into the heater housing. I have measured it up. Not impossible to overcome.
Wiktor
Post by Wiktor »
340cbr wrote:Only the carb.
So the inlet manifold i s from 340?
B172K Power ;)
Sold
Damaged
340cbr
Post by 340cbr »
Since the inlet manifold and the exhaust manifold are joined, yes we kept the 340 manifolds. The exhaust manifold from the 440 Gl is better though.
340cbr
Post by 340cbr »
classicswede wrote:The big problem with the 16v renault engine is the the air intake goes direct into the heater housing. I have measured it up. Not impossible to overcome.
Could you explain with images if possible? :wink:
340cbr
Post by 340cbr »
The F7P (1.8 ) and F7R (2.0) engines from Renault are a improvement from the 1.7 litre engine. In the Renault's the F7P (1.8L) uses the same gearbox (with slight differences in the gear ratio) from some F2N (1.7) engines. Therefore i think the engine will fit in the 340 and the housing for the rear drive configuration maybe will too.
I forgot to tell that both switches for the 400 Turbo engine or Renault F7P/F7R engine will also mean switch to fuel injection system :D
Best bang for the buck has to be the 1.7 turbo.
340cbr
Post by 340cbr »
foggyjames wrote:Best bang for the buck has to be the 1.7 turbo.
Maybe :wink:
The Renault engine will give 140...150 bhp non-supercharged, therefore the revs will go up in a uniform way. With the Volvo turbo engine, it means that at some point you will have a surge of torque that might be difficult to handle while in powerslide. I don't know which one to choose :lol:
