speedo woe
speedo woe
The cable on Dekay`s 340 is hanging out of the hub. I can see a rubber bush on the back of the hub and the end of the outer cable has a flanged ring of the same diameter as the bush`s outer. Is there a clamping device missing to butt these together or does the flange go inside the bush. If so how far and does the bush have to come out first and fit to the outer.......Ive fettled it temporary with an overtube and clamp,seems ok for now. Mr Haynes is no help with drawings or instruction.
Neil.(i'm not old,Im only 48)
- petefarrell360
Sounds that way, there's a weak point just after the back of the hub, so they break there normally, appearing as though all is well, as it gets flexed on tight turns. With mine I could push it back in and it would work, until you took a tight left turn, as it would pull it free again. Indeed, a new cable cures it.
