what next?
Posted: 06 Mar 2006 07:56 pm
by ebdl
Further adventures of the mk.II variomatic.
Right, so I've replaced the carb with a decent one and the problem of hesitation/no revs when applying the accelerator has gone. I still don't think it's running properly and it's running very rich - I can't get it to idle anywhere near two full turns of the mixture screw. Sometimes it'll just run very fast and I can't get it to idle smoothly at all (and yes, the carb bolts are all nice and tight). Very embarrassing not being able to get it in gear with a huge queue behind me at the petrol station because the revs wouldn't drop down low enough to get it into Drive. Also when I lift off the accelerator, the engine braking is accompanied by a load of crackling noises from the engine.
What should I be looking at next?
Thanks,
Posted: 07 Mar 2006 02:35 am
Coming to the Donny meet? We could take a look
Sounds like it's running pig-rich. Is it lumpy at all? Those engines develop a clear chugging sound when running rich. When the mixture is set right, they're beautifully smooth. Nessy's is a bit rich at the moment, so that it just starts to shake if left idling for more than about 20 seconds.
Posted: 07 Mar 2006 03:03 pm
by ebdl
It's definitely running rich... mostly because I can't get it to run any other way. Someone mentioned air/vacuum leaks as a possible problem in the past. Does this sound likely? Where would I look for them?
Not sure I can make Donington - the medics' rugby team are taking on a touring side from America, possibly too much of a comic opportunity to miss. (And I managed just over 100 miles off the last tank, which would make for a very expensive 250-odd miles up there.)
Posted: 07 Mar 2006 08:30 pm
Ok, sounds like you have a monster vacuum leak, and you're having to run it majorly rich to compensate, but that results in a high idle.
Take it all apart (yes, all of it
), replace anything that looks leaky, tighten it all up, and you should be AOK. Also verify that the breather hose is hooked up, and that the restrictor is in place - you should be able to feel it as a hard 'nobble' in the hose. Gemma managed it, and she's a
girl
Posted: 07 Mar 2006 09:06 pm
Countdown to hell breaking loose....
5....
4....
3....
2....
Posted: 07 Mar 2006 09:16 pm
by V6 Man
Go on Gem, I'll hold him down while you kick him.......
Posted: 07 Mar 2006 09:21 pm
by petavius
Do I laugh or cry?! I guess its a kind of back-handed compliment!
Posted: 08 Mar 2006 09:42 am
by ebdl
Hmm... sounds like a job for the easter holiday in 5 weeks' time.
Thanks for info. When you say take it
all apart, I presume you're just talking about the vacuum system and not the whole car
I learnt what little mechanical knowledge I have on 2CVs, so you'll have to excuse me if my understanding of these things is a little basic.
Posted: 08 Mar 2006 12:07 pm
I think he means teh entire carb! Thats what I did on Fake, and needed to do on Kar, make sure yuo do it on newspaper, and a digi cam helps when you after you forget how it goes back together
Posted: 08 Mar 2006 08:22 pm
Yeah, take the carb off and take it to bits. If you have the time / inclination, do the manifolds as well. Check the manifold to downpipe nuts for tightness while you're there...if they're loose, it runs like a bag of spanners.
