Ignition control for megasquirt, there is so many ways to do it, I chose Bosch module and renix wheel, I think nobody has not used Renix wheel before as it is not very well suitable.
You need to make this, you can see this assembled from link on my first post, but you really should use proto board, it is called also vero board, I think, board that has lot of holes and you solder components to it and make connections with jump wires.
I'm indeed building this to my 360, I have been running megasquirt with fuel only about an year now. Megasquirt has MAP sensor, it is used for fuelinjection as well as ignition if one adds that to megasquirt too.
Information from wheel decoder:
http://megasquirt.sourceforge.net/extra ... wheel.html
Information from ignition that I use:
http://megasquirt.sourceforge.net/extra/setup-msns.html
From Ignition selection link on that page you can see all available options. Usually everyone puts 36-1 wheel in but for me that is much more difficulty than using weird renix wheel. I have no tools or skills to add extra wheel to crank pulley and then hall pickup, can't just glue that on place so I find it way too complicated.
Pressing buttons is what I find simple, others may feel this opposite of course.
I have one ignition map for Renix, don't know if that is B200K or E/F, but it is from Haynes and looks bit odd, I think pressure should be reversed 0=100kpa and 80=20kpa
However bit hard to get those numbers right from it as it is 3D illustration, would be great if you can source nice 2D ignition advance table
My car did not started yet, it almost did, but not quite, there is lot to research from wheel decoder settings until it works I think, also ignition advance is bit problem as I have no idea when it sparks, should use timing lamp that I do not have and also friend that is busy
here is link to startup datalog, I'm bit worried that one rpm shows something that could be ok and other shows some reading that F1 cars should get when driving!
Lot to learn with this indeed, but messcircuit works
http://www.janiervast.com/projekti/onge ... 171449.xls
