Dashboard lights out on 360GLT
Posted: 24 Mar 2006 04:18 am
by bambi
The lights on my dashboard behind my speedo etc don't seem to be working. Are there bulbs behind there that should be changed or is it something else?
Is there a checklist of things to check.
The lights behind the warning indicators – battery, brake etc..
Help much appreciated as driving at night is a problem...
Re: Dashboard lights out on 360GLT
Posted: 24 Mar 2006 06:40 am
by cam740
bambi wrote:The lights on my dashboard behind my speedo etc don't seem to be working. Are there bulbs behind there that should be changed or is it something else?
not being a smart arse but you HAVE turned em on on ya dash havent ya???
I only ask cause I had the same problem when i got mine
failing that check the fuse - that was teh other problem I had with mine!!!
and welocme ot Another aussie!!
Posted: 24 Mar 2006 06:45 am
by bambi
Nahh, not a stupid question as there is a switch thing at the right hand side of the dash at the base but that light doesn't work either and have tried that switched on with and without lights ignition etc.
Previous owner said they just went out one day...
Any idea which fuse (is it in the main fuse box?)...
Yeah not enough 360's in Aust.
Posted: 24 Mar 2006 06:49 am
by cam740
bambi wrote:Nahh, not a stupid question as there is a switch thing at the right hand side of the dash at the base but that light doesn't work either and have tried that switched on with and without lights ignition etc.
main fuse box under the bonnet.
IIRC its a fairly high amp fuse but cant remember which one exactly!!!
I think the prob i had with mine was that the a/c compressor had a short and kept killing the dash lights - i'm fairly sure tehy share teh same fuse!!
Posted: 24 Mar 2006 07:49 am
by arnagath
Behind your speedometer there are two seams/connectionpins (i dont know real word for it) which might be loose.
To check that first you have to remove interior"shield" under dashboard.
Then follow wires which goes to speedo and swing those seams. Problem is solved if it does work. Ive done that to mine and it always works
Posted: 24 Mar 2006 10:18 am
by pettaw
pull the lower dash cover off, held on with 4 clips and wiggle the left hand multiplug connector as you look forwards at the dash.
Do it with the lights on and should fix it nicely. If it keeps doing it repeatedly then you'll have to take the dash out and clean the connectors both on the dash and also on the multiplugs.
Edited for spelling.
Posted: 24 Mar 2006 12:58 pm
by arnagath
pettaw wrote:pull the lower dash cover off, held on with 4 clips and wiggle the left hand multiplug connector as you look forwards at the dash.
You said it more understandable
This was also what i ment
Posted: 24 Mar 2006 01:22 pm
by pettaw
Yeah, maybe but try getting me to type Finnish
Posted: 26 Mar 2006 02:07 am
by bambi
Thanks for all your help.
Took the dimmer switch out today and found it wasn't connected, connected it and whammo!! Lights again.
So much for the previous owner saying they had "just gone out"....
No more torch light drivin at night.
Posted: 26 Mar 2006 05:28 am
by MJ
Yeah from experience I know driving without dash lights is a bit difficult. judjing revs+gear to speed and sometimes getting a glimps with streetlights. What's worse is when lights are reversed, eg indicator lights on solid, window heater light on when it's off, and worst of all full beam light on when dipped
I had this problem last winter, often when it was damp. The connectors were suggested as a cause and I had a fiddle, but didn't seem to fix it, but it just fixed itself...
Posted: 26 Mar 2006 12:52 pm
by Ronnie
Thread Hijack:
I'm sure someone on here has swapped all the bulbs in their dash for LEDs, a brick driver I think... Who was it and how did you do it? Direct replacement? Pleased with the result?
