oil change
ch
oil change
Post by ch »
i need to get my cars oil changed, but i dont know how much oil goes into B200E :roll:
340 DL 1.4 CVT 1986 R.I.P.
360 GLE 2.0 1987 for spear parts
340 GL 2.0 1983
About 4.5 to 5 litres.
Dont forget to replace the sump plug washer and use a volvo filter.
ebdl
Post by ebdl »
Are sump plug washers quite generic parts or do I need to get hold of a specific sort when I change my oil?
might as well get one from the dealer when you get your genuine filter. part no 11998 costs less than a quid. And don't overtighten, if you've got a torque wrench then set to about 25 Nm.
Nick C
Post by Nick C »
and if your torque wrench has a 3/8ths end, you can use it directly to tighten it up...
a word of warning, when I did mine a couple of weeks back, I found that the thread was damaged and tried to strip when I put it back in :( luckily I was able to borrow a suitable tap off the Uni Engineering department to clean up the sump threads, before fitting the new plug.
