Free - 340 1.4DL
Ali
Free - 340 1.4DL
Post by Ali »
Right well i've managed to hang onto it for as long as possible but now its getting to summer parents want the drive back :( Doubt it'll be much use for an everyday driver as there's nothing left inside other than the dash and roof lining. Make a good drift/track car, good body with no rust (when you jack it up on one corner the door actually shuts unlike my glt lol)
Failed its MOT in October on:
Rust on front valance
Rust at end of front cross member
Excessive corrosion to main brake pipe
All relatively easy things to fix, as the car has been sat there for a while I don't know how the brakes are, etc but it started up fine a couple of months ago when I tried it. Make an ideal drift project, just needs some buckets sticking in and the diff to be welded,
If it doesn't go then it'll be hitting the scrappy sometime within the next 3weeks,
Ali
I reckon the MOT station was picky - most 300s don't fail on front valances unless the leading edge is clearly sharp.
bennett
Post by bennett »
you have pm
990
Post by 990 »
The garage failed mine on the front valance - however they were actually refering to the Main front bulkhead (which is very costly to repair) :shock:
Volvo 360 -- Small Car - BIG Ideas
E990 UBA Volvo 360GL - Vanised
D133 OBU Volvo 340GL - Died
F330 FWB Volvo 360GLT - She Runs :)
GJ53 GPF Volvo S60 - Daily
Ali
Post by Ali »
Nah on this its definately just the front valance, the guy marked it up with yellow chalk and showed me the bit he meant, its due to being 30cm from the engine :roll:
willy b
Post by willy b »
sorry to be picy, but do you have any pictures?
Ali
Post by Ali »
Sorry forgot to update this thread, its found a new home now,
Ali
