Steering column UJ - 1989 360
Posted: 12 Apr 2006 03:06 pm
by mtucker
Hi,
I need one of these as mine has cracked (or something similar), anyone got one lying around?
Posted: 14 Apr 2006 02:40 pm
I do have a spare one around.
If you have having some bits I can send it with them.
Posted: 14 Apr 2006 03:51 pm
It's a PAS one Dai. If you have a PAS, do you have the rest of the column ;)
Posted: 15 Apr 2006 10:14 pm
:oops:
No its not a pass one. I'm looking for everyone though.
Posted: 17 Apr 2006 01:07 am
by mtucker
hi Dai, sorry havnt got back to u sooner, moneys abit tight at the moment so I cant really spend out on suspension, possibly over the summer perhaps.
If your still prepared to send me the UJ (I assume the UJ is the same on both PAS and non PAS columns) when could you get it to me by and how much as I'd imagine its fairly heavy.
Posted: 18 Apr 2006 08:46 pm
It isn't the same, sadly.
Posted: 21 Apr 2006 01:15 am
by mtucker
hi, after searching eurocarparts they have a steering coupling listed, I googled it and its basically the UJ, but they only have one? so are you sure there difference (lol I'm sorry, I'm not doubting you as you've basically rebuilt your engine which far far exceeds my mechanical knowledge)
unfortunatly I cant link directly to the page as its created dynamically.
Posted: 21 Apr 2006 01:32 pm
by Ronnie
I think you want that rubber disk, sometimes called a steering dampner. It's kind of like a UJ, a very, very cheap one - which is why they always fail.
PAS UJ are a proper steel UJ but need a completely different shaft (I think).
The euro car parts "steering coupling" is probably what you need. Be worth talking to Volvo thoug, if there's only a couple of quid difference then I'd get the original part. Open the bonnet and have a look down your bulkhead on the drivers side and you should see a nasty looking rubber ring at the upper end of your steering column.
Mine is on it's way out too, although I can't feel it in the steering yet. Both my previous 360's had to have these replaced.
Buy the replacement new as second hand ones are ready to fail if they haven't already.
Posted: 21 Apr 2006 03:06 pm
by ebdl
Yes, if it's the part Ronnie's talking about you may as well just go straight to your Volvo dealer. I replaced the one on my 360 GLS and it cost me about £12. Makes a huge difference to the feel of the steering. It can be a bit of a bugger to undo the nuts/bolts on the old one if it's twisting a lot.
