Fitting alloys
Fitting alloys
Mr Haynes has a note saying that a shorter speedo cable is needed when going from steelies to alloys due to the potential of fouling on the wheel.
Does anyone have any info on this? how it fouls?
They're steve's old 5 spokes
also just as a straw poll, what size tyres are people running (drifters need not apply, that'll only confuse everything!)?
Both the ones on Ray and the ones on the Panther where 175/something/R13s but the ones on the alloys are 185s
- 340GLT
No fouling probs!!! You will be fouling the grease cap too if that teh case.
Standard steels run 175 70 13's so as a rule you should go 185 60 14's?
I run 195 50 15's. Go on www.toyo.co.uk they have a tyre converter thing.
No reason for the spedo cable to foul at all. Weired
- foggyjames
I think Nessy is pimping 185/65/14s, but I'm not too sure off the top of my head. 60 profile is closer to being 'correct'.
Someone at Haynes was clearly honking on the crack pipe even harder than usual that night...
GLT's speedo fouls kinda much.. It shows ~10km/h too much. Cable is new part from Volvo so it must be the meter it self.
- foggyjames
When they say foul, I read it as the wheel rubbing on the cable somehow, rather than reading incorrectly.
- foggyjames
Appears to be the same...
- foggyjames
Suppliment for readers from Brum...
....go inside, eat cake, look out of window and see pikeys running away with your mad tyte dubz, and cry a little...
Fixedredline wrote:In my opinion at least one lock nut per wheel would be a worthwhile addition, especially if you live in either Liverpool, Brum or Milton Dump
