Shiny Nessy
Shiny Nessy
So work have told me that I can't use Nessy for work visits because "it looks like a shed" (i.e. won't give the right image). "The silver one would be fine". Yes, but I don't make such an obscene profit from the mileage payment if I take the 25mpg 360....
Hereby, I present 'the solution'...
EDIT: Note how matt the door is in comparison.
Wet-sand, then compounded, then polished. This panel isn't 100% there yet, partly because I polished it in the dark...but great things are happening to the crappy-looking-car-that-can. sm56
MJ
Post by MJ »
And make sure you do the whole roof, not half of it ;)
Cue Ludlow Nessy pic :D
Post by petefarrell360 »
You mean these!?!
Certainly looks better mate, I need to do a similar job to the Variomatic to bring the paint back up to it's former glory after many years outside. The colour comes back with just some good wax, but there are quite a few imperfections that need cutting out, what was the product you used?
Nessy will be a shining car to be proud of!
Nice job! Damn shiny.. and rather a cool pic too
Ryan cleaned both his 740 and Nessy today (since he's taking her to work tomorrow), and she looks a lot better for it! We had a minor drama involving noticing that it was pouring out coolant (from a loose hose, fingers crossed...), and just had to laugh when we drained the coolant...
After we dropped it down onto some dry drive to check for leaks, I notice that it looked a touch cheeky....so took a couple of pictures...
I think I might invest in some lowering blocks for the rear. The front springs have sagged pretty badly (although you don't really notice while driving it, but the rear is still tight as a drum).
MJ
Post by MJ »
:P That's the one
Sorry couldn't help it ;) Looks good from what can be seen in that pic, hopefully the paint will come good all over when finished :)
EDIT: Yuk, that coolent looks bad, methinks our coolent may look rather bad when drained :(
I tell you what Nessy really has got something about it that looks bloody bad ass!
Water + Oil = failed headgasket....probably....will keep an eye on the concentration of oil related gunk in the coolant.
Or maybe that's the source of your mysterious coolant loss......manky coolant like that is par for the course if you just top the coolant up with water rather than antifreeze ;)
Our 340 B14 had mayo in the filler cap when the thermostat went on that and it wasn't warming up properly.....
There was one hell of a lot of muck on top of the coolant, and I have been adding anti-freeze. It looks like the radiator is holed, so that will explain some of the loss. :?
We'll flush both systems (oil and coolant) properly, and see how it behaves after that.
Nice :)
It is real pleasure to see how old cars can still shine more than those 10 years younger ones if just taken care and spend little work on them.
There is many newer cars at my parking lot, but my car still shines better, even it has been now 2 years since I did polish it, last time I did wax it about year ago so soon need to do it again, but still it has bit of that wet look too.
But I do have problems with rust, passenger door is brown of rust 2-3cm from bottom, also there is some other spots too. If I would just have place or bit more money so I could get it sorted, then it would be quite nice.
5lab
Post by 5lab »
when was the oil last changed? a lot of standing around will probably do that..
gunk in the oil may be my fault :oops: i'd see how it behaves..
has she got a new radiator yet?
5lab wrote: gunk in the oil may be my fault :oops:
Only that? :P
1stRaven
Post by 1stRaven »
foggyjames wrote:Ryan cleaned both his 740 and Nessy today (since he's taking her to work tomorrow)
Yep, Guess i'll have to post more now that i am a 300 driver.
[center]
[QUOTE=foggyjames]...Ryan's car is pretty much spot-on....[/QUOTE]
[/center]
No, still on the old rad...and the old oil. The less said about the latter, the better....I'm not proud of it! But still, Nessy is the car which defies all the odds and still keeps going, so I have to make the occasional homage to that!
