340 gearbox options.
as you all know i am hoping to build a R5 powered 340, i am wondering what options i would have in the gearbox department, as i have been told that constand sharp starts and drifts dont do it any good, reason for changing G/box is that the propshaft will be changed for stronger one and theres no point leaving the standard G/box on it, as wont be stock power...any help as always would be greatly appriciated...
lil mike
lil mike
I don't think theres going to be too many problems with the box, there's a couple of guys running 350bhp through what I think are still the stock ones, and again as far as I last heard, Iains 400 turbo'd 300 is on the standard box with modded prop, and he's pushing 220ish now I think?
Iif you really really want to, some of the crazy fins and swedes are looking at porsche 928 drivetrains as well as a few others that have been mentioned.
Have a nosey on 300power, theres a fair bit of mad stuff over there, so always worth looking at the pictures and hope babelfish can do some translating!
- petefarrell360
Ah yes the gearboxes are the same I believe, it's the final drive that differs the 360 carb and injection cars had different ratios believe it or not! I can't quote what they were without doing some digging, but Foggy is one of the men in the know.
- petefarrell360
Knew I'd seen it on here somewhere, not that it was the exact answer to the question from the first post!brad360 wrote:My 1986 Volvo 340/360 owner's manual tells me, p 101:
Reduction ratio, final drive
5 speed 1.4 litre models 3.82:1
4 speed 1.4 litre and GLT 3.64:1
1.7 litre models and GLE 3.45:1
2 litre* carb models 3.27:1
*(2 litre low octane models 3.64:1)
The gearbox ratios are the same for all configurations, except some havea 5th. No mention of diesel.
1986 manual is then different than 1988 manual as mine 1988 manual says(page 105): 1,7l and 2l inj. to have same 3,64:1
5 speed 1,4l model 3,82:1 only models that were sold in France has 3,45:1 and that 3,27:1 was only found in 1985 model in here.
Different market area different gadgeds
I don't think we had specially different octane versions at all in here either.
Can't understand why they just make a car and sell it to all as it is, every country tries to be special, selfish and foolish
For stronger gearbox I think that there is not much to do, maybe fit Alfa 75 driveline?
M47RII is almost same as in 240, there is no really lot stronger options easily available. Don't know if it would be possible to fit internals of M46 and if it is any use at all, it may not be that much stronger.
It is not horsepower that destroys box, but torque some has rumoured that 250nm is max at constant usage, but I'm not quite sure about that, anyway your gearbox is not new, taking it apart and rebuilding would provide perhaps best solution as your car is probably going to stay light as possible?
Differential will be anyway weaker than gearbox, of course welding should help there, but still it is quite weak.
Jani's right, the later 1.7's I think had the 3.64 (well, Fake definately has) not sure if it was a time related change, or country related though
Well there's one way if you want to keep M4x series box..jtbo wrote:For stronger gearbox I think that there is not much to do, maybe fit Alfa 75 driveline?
http://www.ssf-pyora.fi/
you dont really notice the welded diff when at normal driving speed, you only have to watch it in the wet when taking sweeping corners at speed.lil mike wrote:well then that got me no where...
what would welding up the diff do to the everyday handling??? obviously it would drift reasonably well and parking is a bitch but what else???
lil mike
thanks
lee
If I remember correctly price was near 2000€, obviously that route is far out of reach from averagel Volvo 300-series driverFuse wrote:Well there's one way if you want to keep M4x series box..jtbo wrote:For stronger gearbox I think that there is not much to do, maybe fit Alfa 75 driveline?
M47RII is almost same as in 240, there is no really lot stronger options easily available. Don't know if it would be possible to fit internals of M46 and if it is any use at all, it may not be that much stronger.You can get strengthened versions of M4x boxes from SSF-Pyörä Finland but those are NOT cheap.. But those would take much more power than stock box as those are mainly built for rally and rally cross use.
