Please introduce yourself here, your Volvo 300 hobby... NO technical support, parts requests or car advertisements here
Carl wrote:
Man, I wish I could afford some stage rally action!
Tell me about it
When we get a chance to sort our $hit out-it'll be going back on injection,chairs flung in the rear,bit of axminster pelted at the floors and hit the lanes-ye ha
Don't Quaife do a better gearset for the M47? I'm just going to lower the diff ratio a fair bit. It doesn't remove the 2nd-3rd hole, but makes the effect of the hole less noticable
Changing only one gear ratio could come lot chaper, but sequential box with very strong gears does cost some money, however it is very very fast and strong then
Maybe not for daily driver however. Noise of straight cut gears is something you dont like to hear every day
foggyjames wrote: I'm just going to lower the diff ratio a fair bit. It doesn't remove the 2nd-3rd hole, but makes the effect of the hole less noticable
Afraid not, that vid on Otterburn was the car with 4.78/1 and as can be heard it's still $hit.
It is the gearing of the box that needs alterring not the final drive.
The car has a direct top 5speed straight cut box with it that when it runs right the diff ratio controls terminal velocity but only alters slightly how it pulls thru the gears.
Think Bilbo has a 4.78/1 diff spare if that's the way you wanna go.
Regards Sven
Only possibility is then to order new gear sets to box and install them, my memory tells me that Foggy has seen Quaife selling gears for 240 box, those should fit to out box too?
But this memory of mine, it can be way wrong in this too.
I do know where to get gears in Finland, but won't be cheap...
