Road speed from RPMs - help?
27.86
Post by 27.86 »
Hi. I'm looking at getting a 360 with a duff speedo. I know it's possible to calculate road speed from a combination of revs & gear, but I'm wondering how it's done. The car's a 2 litre - don't know if they all had the same gear/diff ratios?
Any hints, guys? :roll:
sven360
Post by sven360 »
most 360's come with 3.64 diffs
Wipe the crud off the diff and a sticker will reveal ratio.
If you got 3.64 let me know and will check what rpm apply to speed limits for ya.
Carl
Post by Carl »
I've found this quite helpful in the past if you know the values to work with:
http://www.fisc-racing.com/misc/ratios.html
Carl
But previously:
1988 Volvo 360GLT
1988 Volvo 360GLT
1984 Volvo 340DL
www.carlgibbs.com/gallery
27.86
Post by 27.86 »
Thanks, Sven & Carl. I'll get the information & see what I can do!
Wouldn't it be more to the point to fix the speedo? It'll either be a loose cable (easy), a snapped cable (also easy-ish), or a broken speedo head (also easy).
Carb 360s apart from really early ones (3.28) had a 3.36:1 diff, and injection ones had the 3.64 as the guys above have said.
Bilbo
Post by Bilbo »
u can work it out like me :roll:
rpm/ratio = gearbox output
gearbox output/diff ratio =wheel rpm
wheel rpm x 60 = wheel rph
wheel rph x rolling radius of tyres = mph
:wink:
the original g/box from my 360 GLEi had a 3.43ish diff, in between the carb one and the GLT one :?
d3k4y0
Post by d3k4y0 »
Bilbo wrote:u can work it out like me :roll:
:wink:
I wouldn't want to do that every time i passed a speed camera! ;)
Aprox for most volvos is
1st 1/2 x rpm 4000rpm = 20mph
2nd 1 xrpm 4000rpm = 40mph
3rd 1 1/2 x prm 4000rpm = 60mph
4th 2 x rpm 4000rpm = 80mph
5th 2 1/2 x rpm 4000rpm = 100mph
That is not 100% by any means but does provide a good guide to what speed you are doing and can be worked out very quickly
My old man used this in his Amazon for years
Post by redline »
foggyjames wrote:Wouldn't it be more to the point to fix the speedo? cheers James
last time I looked the redlines speedo worked just fine lol
27.86
Post by 27.86 »
Thanks for all the good advice, guys. I will get the speedo looked at (if I get the car), but have to get it 100 miles home first!
Thanks, Mr classicswede. Will be up in your neck of the woods in a couple of weeks (hopefully by Volvo!) - going on holiday in the Lleyn Peninsula.
My (potential) car's a 1989 360 GLE on standard steels. Not sure of the rolling radius/gear ratios/diff ratio yet. Time to get the Haynes manual out!
No problems.
The Llyn penisula is a very nice area (not far from me at all).
Imo it is the most Welsh area of Wales.
I had the spedo head out of my old 360 and the ratio on that is the same on the 340 with steels.
I can tell you that a 360 carb does 4000rpm at 60 in 3rd, and the same at 100 in 5th. :)
I'm sure someone will sell you a working speedo...Mr Farrell? I'll even adjust it to match your current mileage, if you want.
Post by petefarrell360 »
Good point James, I hadn't thought of it being the actual speedo itself, however they normally still read speed, and just don't record the miles when they lcok up. I'd bet on it being the cable, connections or fitting in the hub as previously suggested.
27.86
Post by 27.86 »
Thanks for the advice, everyone. I've got a spare 340, so could take the speedo out of that, if needed. Thanks for the offer to change the mileage on it for me, James.
Please could someone let me know what to tell my garage to check when it goes in for a service next week - it would be good to get the speedo fixed, if possible, before my 600+ mile journey!!
