340 Boot Struts also rubber door seals
gunslinger
Post by gunslinger »
I'm searching for boot struts for a 340 DL 1986 model (1.4 litre). I think the gas has all leaked out and I have no idea if they can be refilled. Also I need the rubber door seals that sit between the door and the glass windows. These are the seals that are mounted horizontally at the bottom of the windows. Thanks
Gunslinger :?:
You won't be able to refill the struts, but you can get them from GSF for not too much money.
The seals are available from Volvo I believe, but only for the 3 door version and need to be cut down for a 4/5 door.
tigersport
Post by tigersport »
I have a couple boot struts right off the back of a 340 DL 1989, and were still strong when they parted company with said car. They are a replacement set as the orignals went, so they are not all that old.
