Not Starting
Not Starting
Went to move my B172 today so that I could do some work on the B14 (gravel/shingle drive, and the only bit of useful concrete is where I leave the B172)
Went to start her, and turns over, but no catching..... ever. Left the key turning for quite a while. No fuel had made it up to the fuel filter (about 8" fom the fuel pump).
Used a pump on suck to pull ome fuel through (incase there was an airlock) put in back together, still no kick. I guess this points to the fuel pump, she's been idle for around 12months, would it pack up when not being used? Or can anyone think of anything else?
Means that I didn't get any work done on Kar in the end :(
5lab
Post by 5lab »
try leaving her going for longer - the fuel may be taking its time to get there?
Yeah, I wondered that, managed to flattern a freshly charged battery :(
5lab
Post by 5lab »
tried just filling up the pipe to the carb manually? that way you could see if the engine would fire, had it got fuel..
