Chesh740R
Posts: 159 Joined: 16 Aug 2004 06:23 pm
Post
by Chesh740R » 16 Sep 2004 09:39 pm
For Sale, Complete Unused never fitted Fuel Trip Computer for the 300 Series.
Comes Complete with Instructions and the instructions say it can be fitted to both 1.4 and 2.0 Carb Engines.
£75
5lab
Posts: 3454 Joined: 31 Jan 2004 01:44 pm
Post
by 5lab » 17 Sep 2004 07:30 am
more from an interest point of view (i'd want one, but they're just too fecking ugly - unless you think it would fit where oil temp should go??) what feeds does it take in?
pretty sure it'll sell on here - you got any other bits floating around?
Chesh740R
Post
by Chesh740R » 17 Sep 2004 09:03 pm
As for the feeds it uses.
There is a turbine type sensor which you plumb into the fuel line to the carb and this measures fuel flow.
And it has another sensor which mounts above one of the rear driveshafts and that counts revoloutions of the road wheel.
Thats it, pretty simple device.
Janitor
Posts: 115 Joined: 18 Jan 2004 08:58 pm
Post
by Janitor » 18 Sep 2004 01:43 am
you'll have to stop smokin those back tyres then 5lab if you get 1
5lab
Post
by 5lab » 18 Sep 2004 03:48 pm
i have to now anywyas - my new tires/wheels are on and my last ones are more bald than.. a very bald thing
JOHN360
Posts: 123 Joined: 25 Feb 2004 11:47 am
Post
by JOHN360 » 29 Sep 2004 02:21 pm
I take it should work on the GLT as well ? Can you email at
jallam@supanet.com to discuss further.
Cheers,
John.
5lab
Post
by 5lab » 29 Sep 2004 04:22 pm
it claims not to, but i think that it would.
Carl
Posts: 1275 Joined: 17 Jan 2004 12:29 pm
Post
by Carl » 29 Sep 2004 05:20 pm
5lab wrote: it claims not to, but i think that it would.
Surely it wouldnt if it uses a turbine in the fuel line to measure fuel consumption becuase the GLT is injection and has a higher pressure fuel pump, so it wouldnt be calibrated properly. Although i could be talking out of my arse
5lab
Post
by 5lab » 29 Sep 2004 06:41 pm
well you see, all it has to do is mesure the fuel flowing thru the pipe - the pressure is irrelevant because a liquid is the same size regardless of pressure
Carl
Post
by Carl » 29 Sep 2004 07:51 pm
5lab wrote: well you see, all it has to do is mesure the fuel flowing thru the pipe - the pressure is irrelevant because a liquid is the same size regardless of pressure
But fuel is used differently in an injection system. The high pressure pump at the rear supplies the fuel rail which acts as a 'mini-tank' for the injectors, but unused fuel is also returned back to the main tank. So in fact, if i'm working all this out correctly the same amount of fuel will always be flowing if you put the turbine before the injector rail.
Posts: 9361 Joined: 29 Jan 2004 04:20 am
Post
by foggyjames » 03 Oct 2004 03:07 pm
It doesn't work on the injection engine. You win this one Carl
Carl
Post
by Carl » 03 Oct 2004 05:12 pm
WOO HOO
Duvel78
Website Admin
Posts: 2260 Joined: 29 Dec 2003 01:33 am
Post
by Duvel78 » 04 Oct 2004 11:57 pm
Still for sale that computer?
V3M for life!
Post
by foggyjames » 05 Oct 2004 12:08 am
Hmm....well I guess so technically, but I'm still trying to do a deal with Chesh!!
