240 intake manifold fit under 300 bonnet?
Ali
Post by Ali »
As the title says, does anyone know if a 240 GL manifold will fit under the bonnet of a 300, the type that goes into a kind of box section at the top of the runners, don't worry don't plan to change it for mine, other ideas brewing :D
That will be the K Jet.
I think I have read some where here that it will not fit. You could maybe shorten it to get it in.
sjs
Post by sjs »
I think you'll hit the hood. The K-jet intake is VERY high.
I haven't got the slightest clue, why to fit a K-jet into a 300 series, when they came from the factory with EFI. :?
Fit a megasquirt, and a EFI manifold instead.
My B234F manifold on my 16v engine is already VERY close to the hood, not to mention the intake camgear, that's around 2cm from the hood + the cambelt housing.
340DL 1986 B14 4E (72hp, 110Nm)
360GL Injection 1990, B200F (108hp, 150Nm)
Trashed:
343DL -79, 2x340DL -83, 340DL -84, 360GL -87, 340GL -88
Fuse
Post by Fuse »
I don't see anyone mentioning the K-Jet, only the manifold.
That manifold with longer runners and some size plenum is much better than the EFI manifold, which doesn't have any kind of plenum at all an runners end on the tb.
Many people have welded a fuel rail on the K-Jet manifold and modified the efi-tb to fit, as it's much better in high-hp appilications.
Though it won't fit in 300-series without cutting the hood I guess.
Ali
Post by Ali »
Yeah it was to cut down to make a custom manifold, i've decided its too much work now anyway and hopefully going to get the proper thing
volvo360gle/340turbo
Post by volvo360gle/340turbo »
why not modifiy the bonnet! it would look good if done properly!
1988 360 gle
1990 340 gl (turbo conversion)
1991 340 LE 1.4 (29000 miles on the clock)
Fuse
Post by Fuse »
http://www.300power.com/forum/attachments/PICT2847.JPG
There's a pic of K-Jet intake manifold in 300-series. It doesn't go too high so bonnet doesn't need much modification.. :P
i may hav a manifold ur lookin for! its of a 240 2.3 injection with the k-jetronic injectio system!
Andrew
1988 360 gle
Ali
Post by Ali »
Nah afraid this was to bodge carbs onto so unless anyone has a spare R sport manifold lying around :roll:
Ali
Post by Ali »
I can get manifolds for putting twin webbers on no probs. :D
Ali
Post by Ali »
Oooh really, these are solex so can you get them? How much? pm if needs be
Ali
From what I remamber they are about £150 including fixings. I will check tomorrow morning for you and drop you a PM.
I'll need to put these on the list.
