MJ wrote:Hmm. 80 ish just sounds a low number.
I know this sounds stupid, but when I get to drive the 850 (170ish HP) it doesn't really feel much more powerful, although this is grandad driving, always under 3k revs. In fact I had a fright when overtaking with it, I thought it'd pull a lot harder
850 gives power only when you rev it, that is what I have heard, also suspension setup, sound dampening etc. makes all feel go away, of course it is really fat too and fwd which means that you really can't feel anything what is going on, but very comfy to travel longer distances and easy to control too.
Yes, the site in question. I would like to see weight distribution / corner weights, camber, caster KPI data, spring rates, damper rates etc. Some inertia data would be nice too, braking performance data, gear ratios, rev limit of engine if there is any, suspension motion ratios, steering wheel turns from lock to lock, wheels turning angle etc.
Now all this that I'm asking is really really hard to find from internet, would be great if you could find and put some of these to site too. If you can find those values I can guarantee that you will be number one site on the net after that.
Also real test data from different tires would be really nice, slip curves and other grip data measured.
But I'm afraid this is something I will never see, this information is perhaps too hard to get hands on
Citroen ZX Dturbo -97 -daily-
