rear end-
coilovers
5 linked axle all rosejointed no bushes (very tyte i say)
lsd by mig!!!
lowered 100mm
solid gearbox mounts (billet ali)
front end-
all polybushed
lowered springs 80mm
chassis-
alloy spun 7 gallon tank in boot
alloy filler in rear window
facet red top pump
filter king regulator
all fuel lines internal
poly windows
all stripped out, sound deadening removed
hydraulic handbrake
all brake lines stainless and run internally
battery relocated behind passenger seat
kill switch
fibreglass bonnet
engine-
stock renault clio 16v
twin 40 webers
modified clutch
stock exhaust manifold
custom downpipe
stock volvo exhaust
2.0 radiator
pacet profan
uprated engine mounts
custom steel propshaft
one off throttle cable
wheels n tyres-
front,
7x13 et-7 minilites
175/50/13 yokohama ao48r medium compound
rear,
7x13 et-7 minilites
175/50/13 yokohama a539
this car was built by me (Nev) and the crew in 5 days 9am-6pm started monday!from a stock volvo saloon,and was runnin friday nite!!!!! was out in anger saturday!!!
still needs a rollin road to fine tune things, and i would like to change the spring rate at the rear to a little harder as the saloon carries more weight over the rear. other than that shes a...........
FUCKIN WEAPON!!!!!!!!!!!!!!!!!!!!!!!!!
pics to follow and a small vid!
Little vid with the Pimp 16v
http://video.google.co.uk/videoplay?doc ... 3417325312
