Rear right door handle
germ
Post by germ »
Hi
my right rear outside door handel is broken
does any one know where i can get one?
will
ps it is missing somthing that operates the catch thats why it doesent work.
Volvo 340 Image 1988
Vart
Post by Vart »
if the handle doesn't open the door it could just be a length of thick wire running down from the handle mechanism to a hole by the opening mechanism. i've had this fall off on the drivers door. take the door card off and if it has fallen out its a push fit fix.
or a thought that occured, theres a bolt between the movin the handle and the part that moves the wire. a bolt has fallen off this on the same door of mine before. fixed with a screw and bolt in a fairly ramshackle way but still works.
germ
Post by germ »
Thanks
but i toke it all apart already and its missing somthing that the other side has.
ILL TRY AND GET A PIC ;)
I am also now looking for a rear central locking moter
will
