Uprating brakes/suspension/axle etc
stealthstylz
I've got a few questions lol. I've just been given a 3 door 340 and i'm wondering what the popular modifications are.
1.) How much power will the stock gearbox and axle take?
2.) Are there any popular upgrades for the brakes? I saw something about fitting bmw 325i disks on the front somewhere. How hard is that to do?
3.) What upgrades are available for the suspension?
My plan is to weld in the transmission tunnel from another car and then fit a Volvo T5 engine mated to a 960 gearbox.
Matt
Matt
Re: Uprating brakes/suspension/axle etc
if your doing that you dont need to know about the standard bits, lol.stealthstylz wrote: My plan is to weld in the transmission tunnel from another car and then fit a Volvo T5 engine mated to a 960 gearbox.
5linked rear end and coilovers all round is available if you want to do it. Wont get any change from a grand for serious work like that mind.
Suspension has a fair number of options. A good set of springs&lowering blocks with some good dampers is a good start with poly bushing.
A good range oif wheels are available common pcd 4 x 100mm
Brakes are very good if in good nick - no real easy upgrades at the mo.
Stock box and diff will take a fair bit the prob is the weak point - uprated version available.
stealthstylz
I dont want to 5 link it I could do it all myself, but preferred my mates capri to drive when it had de-cambered leaf springs, anti tramp bars and ajustable shocks to when he 5 linked it.
With the Clio Williams/16v engine conversions are they using the standard gearbox with a custom propshaft or fitting a completely different gearbox?
Matt
Matt
stealthstylz
My plan is to run a conventional gearbox bolted to the engine so would get rid of the rear gearbox completely.
Can somebody please get me a photo from underneath of the rear axle and how its mounted to the leaf springs etc, as i've just been looking for dimensions and the rear axle is the same width as one from a capri.
Matt
Matt
stealthstylz wrote:My plan is to run a conventional gearbox bolted to the engine so would get rid of the rear gearbox completely.
Matt
If you are going to move box to front you need to heavily modify floor and as there is not many that has done this most of information about boxes and propeller shafts is not helping I'm afraid.
stealthstylz
- petefarrell360
Interesting project. I'm just wondering how moving the box forward is going to affect the weight distribution. I know just how heavy that unit is as one with the diff, it's not light! By having that layout it makes the 300 a pretty well balanced car. Good luck, keep us posted, and lots of pics please!
volvorsport
well if you manage to get a an M90 whiteblock keep the prop and final drive , you should be pretty close to what you want .
mount the 1065 diff in the same place as the original one , and the driveshafts might even line up for you .
hmm foggy do you have a 3 series driveshaft , could try it up against that IRS back end iv got .
stealthstylz
volvorsport
Moving the box up front would be great for drifting but naff for a handling car. If you do want to do that and keep some kind of road holding you will need to shift a fair bit of weight to the rear.
- petefarrell360
Yeah, this is why I questioned this above! Adding weight can't be good. The 300 is well balanced due to where the gearbox is mounted, and it's a lot of weight at the rear to suddenly move elsewhere! Throw it into a corner with such a light rear end, and I can't see it gripping too well. The 340 compared to the 360 feels less planted on the rear, and that is purely no spoiler, a smaller differently mounted fuel tank and different, narrower tyres.classicswede wrote:Moving the box up front would be great for drifting but naff for a handling car. If you do want to do that and keep some kind of road holding you will need to shift a fair bit of weight to the rear.
stealthstylz
