from automatic to manual...
mihajlo
Post by mihajlo »
Hello!
Finding Volvo 340 in good condition is mission impossible for me... :-( so I found (in order to buy it) Volvo 240 with automatic transmission and non rust body and I would like to made swapping transmissions (hand is hand afterall... :D ) from automatic to manual M46/7 or M50 from 700 series... (not me but my mehanic :-) )
Is it possible to do something like that and what do I have to have before starting a project...?
I'm asking here first so my mehanic don't laugh to me when I come with silly ideas... :-)
if something can go wrong, it will go wrong.
NO CAR YET (but soon...)
blackbox
Post by blackbox »
it can be done but there is alot to do you need clutch pedal manual brake pedal might need new tail sharft to fit manual might be longer or shorter
Hope that helps
1984 360glt B19 black
mihajlo
Post by mihajlo »
Yes pedals will be story for itselfs.
In Banzai magazine I saw project in which they swap engine and transmission and pedals were some kind of problem to adjust...
In 200 series gearbox is positioned in back of the car (like Alfa romeo 75) or in front by the engine like most of RWD cars:?:
Only in 300 series gearbox is same way as in Alfa 75, all others 200, 700, box is at front.
mihajlo
Post by mihajlo »
jtbo wrote:Only in 300 series gearbox is same way as in Alfa 75, all others 200, 700, box is at front.
thank you for sharing that information... it is good to know... :-)
I supose that will' have to change flywheel and clutch too...... :?
maybe sometging else, but i can't remember anithing atm...
Ronnie
Post by Ronnie »
It means your going to have to take an angle grinder to your car followed by a lot of welding - big job and very probably not worth it unless your going for big power (and questionable even then)
http://www.filterfeeder.eu
mihajlo
Post by mihajlo »
Ronnie wrote:It means your going to have to take an angle grinder to your car followed by a lot of welding - big job and very probably not worth it unless your going for big power (and questionable even then)
you mean if I only want to swap gearboxes it is not worth it?
if it is that way, than better to leave automatic gearbox and drive like car want or wait another car with manual gearbox... :wink:
better knowin' that before is too late...
Ronnie....I think you may have got the wrong end of the stick. He just wants to swap from an auto to a manual on his 240, which can be done using bolt-in parts, as far as I'm aware. Helpfully on 200s, the pedalbox area is a bolt-in panel. On 700s, there's a blanking plate over the clutch cylinder hole on automatics.
Here's what I think you need...
Flywheel
Clutch
M46 / M47
Propshaft
Pedalbox and clutch arrangement
mihajlo
Post by mihajlo »
There IS hope!!! :D :D :D
now I can ask some people to borrow me some money and hopefuly project will begin...
I'l stay in touch with reports (with pics)...
8)
WEEEEEEEEEE!!!!!
ah yes! I almost forgot, THANK YOU!!!!
Ronnie
Post by Ronnie »
foggyjames wrote:Ronnie....I think you may have got the wrong end of the stick.
Absolutely - I thought he was talking about fitting a 200 box in a 300
Fair assumption - that is the usual enquiry, after all :D
I think we ought to change the URL to www.volvo300mania-incorporating-volvo200mania.com sm56
germ
Post by germ »
^^hey james the linky doesent work :lol:
Volvo 340 Image 1988
