Door hinges
Bello
Door hinges
Post by Bello »
Can anyone tell me where to buy new drivers and passengers door hinges for my 89 340?
J340GLT
Post by J340GLT »
hinges or door pins?
Bello
Post by Bello »
oh... i don't really know, haven't had time to check i just thought it'd be a case of complete new hinges, never thought they might come in parts :oops:
J340GLT
Post by J340GLT »
Oh well what is happening when you open and close the door?
I'm sure the hinges are welded on, so it might just be the pins or it might be the check strap?
Let me know once your sure as I can get hold of the parts.
Jay
Bello
Post by Bello »
The bottom of the door is hitting the sill, you have to lift the door and shut at the same time.
Has already worn the paint off almost back to the metal on the top of the sill.
So i guess the best thing to do is to remove the pins and check for wear? you can actually wobble the door up and down...
If it's the hinge do you think i'd get away with spacing it with a few washers?
Thanks for the help btw 8)
J340GLT
Post by J340GLT »
Yes, I definately think its the pins then. Would just replace them as oppose to putting washers anywhere!!
You can try and knocking them out but it can be a bit tricky at times..
Let me know how you get on and if you need me to get you some pins..
and.. your welcome!!
Jay
Cornholio
Post by Cornholio »
Part number 3140643, 70 pence each from Volvo :D
[edit]That's the part number for a five door, may be different for a three door.[/edit]
VADIS refers to them as 'tensioners', we'd call them hinge pins. Much easier to replace with the special tool, but it seems that the Draper one that is widely available doesn't come with the correct attachment.
  • Geraldine - Kia Venga
Post by trabitom99 »
Here's a good recent thread on door hinge pin removal:
http://www.volvo300mania.com/forum-uk/v ... php?t=4802
70p from Volvo? Wow, after being charged 4,50 Euros (about 3 pounds) for a wheel nut I'm pleasantly surprised :-)
Bello
Post by Bello »
Thanks for the info 8)
i really need to stop being lazy and do this job.
To be honest...you'll probably not manage this job without the special tool...
Cornholio
Post by Cornholio »
foggyjames wrote:To be honest...you'll probably not manage this job without the special tool...
It's not always straightforward with the special tool :lol:
I needed a bigger hammer to get the top hinge pin out with Mac's Volvo tool. The bottom one is even trickier as you have to knock it upwards and the hammer has to be hefted between the door and the sill. I don't want to dent either of those.
Will try soaking the hinge again before setting about it for a second time with the 2.5 pound club hammer.
