1983 y reg 1.4
Posted: 24 Jul 2007 02:05 am
by kevywevywoo
help ive got a 340 1.4 1983 the mot has failed due to a part i cant find ..the car has only 39k on the clock so seems a shame to scrap it now .
the part is a reduction valve that sits on the n/s inner wing volvo part no 3298352 it has 4 pipes going to + from master and slave cylinders any help would be great to avoid it going to the volvo heaven everyone i try has newer versions in scrappys that is different or go to volvo part supplier that says part is now obsolete 01506853515
Posted: 24 Jul 2007 05:25 pm
by filthyjohn
I'm breaking a 1991, and if someone more clued up wants to confirm compatability, I'll sort it for you if you like.
ty
Posted: 24 Jul 2007 05:51 pm
by kevywevywoo
a d reg was differnt john so a 91 i dont think will do so looks like ive got a 340 for scrap or repair with 39k weird man weird
Posted: 24 Jul 2007 06:29 pm
by filthyjohn
Don't scrap it! If it turns out it can be retro fitted it's yours for postage price alone. Could you give us some more details on yr car? maybe some pictures?
Cheers,
John.
john
Posted: 25 Jul 2007 01:55 pm
by kevywevywoo
do u have a fax john
Posted: 26 Jul 2007 05:20 pm
by filthyjohn
No, sorry mate. If someone who knows stuff says there's compatibility, I'll just wade in and pull out everything I can, then sort it out after.
Posted: 27 Jul 2007 05:59 pm
by ajdubas
I think I know the part you mean,
I have one, unfortunately, it's attached to my car and in use.
You'd need to find a Mk 2 340 somewhere to get one off, I'm guessing they're specific to mk2s (and possibly earlier?), but I'm not an expert.
Posted: 27 Jul 2007 09:04 pm
by mac
Evnin all, Macs awake.
Pressure reducing valve - as it says on the tin it reduces pressure to the rear brakes to avoid premature lock up under heavy braking (and the ususal result of terminal oversteer).
Ignoring the very early Girling braked cars (twin pot calipers up to chassis no. 377183 - 1980) there are two basic types.
Up to 1985 models (ATE brakes with 8" Bendix servo) there are two part numbers - 3298352 for MT cars and 3293421 for CVT cars. (360's have the same as 340 manual cars even though they have 9" drums rather than 8").
From 1986 (ATE brakes but with 9" Isovac servo) the part nos. change to 3202404 for all manual cars and 3202403 for CVTs.
The differences valve to valve are differing reduction factors and operating pressures with manual cars having a red/ratio of 0.30 and an operating pressure of 3000 kPa. For CVT cars the values are 0.45/2500kPa. There are slight differences in later valves (after 1986) to allow for the greater assistance of the larger servo - BUT the later valves whilst fulfilling the same function are physically different and are not directly interchangeable.
An early car could be "re-plumbed" to take a later valve but unless you are a very confident diy'er I would not suggest you tackle it.
For a 1983 car you really need a valve from a 1981/82/83/84 or 85 car with the same transmission as your own (although MT/CVT could at a pinch be "swapped").
Do try not to scrap for want of a valve though - one will turn up from somewhere.
Hope this helps - Mac.
Posted: 27 Jul 2007 11:47 pm
If the worst comes to the worst, a universal brake bias valve could be used, but I'm confident a direct-swap unit can be found.
If a tidy car risks being scrapped and you've no-where to store it, there are options...
Posted: 28 Jul 2007 02:34 am
by ajdubas
please don't scrap it...
or at the very least, if you do, let me know as there's rather a large number of parts I could do with off a mk2 340. (or in fact the whole car, if I think I can get it through an mot)
