Aftermarket rev counter
kaos
Post by kaos »
how easy is it to install these puppys?
Considering i cant remeber seeing a coil pack in the engine bay etc. and there normally 3 wire units.
d3k4y0
Post by d3k4y0 »
Not as easy to install as the OEM one I'll be willing to bet, that's more or less just plug and go.
Is there a reason why you want an aftermarket one?
It's not hard as long as the renix has a rev counter output (should be a grey wire from memory). The renix has the coil built in. Even if the renix didn't have a wire, depending on the rev counter, you might find that you can wrap a wire around the king lead, and the EM field is usually enough to trigger a rev counter. Both the grey with and the king lead way would guve you 2 pulses per rev, which is what the stock counter needs, and I'm guessing is the same for an aftermarket. The only other 2 wires you would require are +12 and gnd, preferrably switched ign for the +12.
Depends if you want the try hard 12" aftermarket gauge with shiftlight, or to look standard as to which you get I'd imagine ;)
kaos
Post by kaos »
aftermarket for the shiftlight function mainly but i know where my shift points are at the moment.
and because i want it on top of the dash so its more visable.
wheres does the OEM rev counter go to? mines an 89 1.4 340
No problem wiring it in +/- its was more wheres the feed etc :)
i shall whip the dash out over the weekend again amd try and see this grey wire.
MJ
Post by MJ »
The stock rev counter goes in the dash next to the speedo, I assume you have a clock there now. :)
Unless you mean where does the wiring go...
kaos
Post by kaos »
yeh ive got a big ol' clock there.
So its a grey wire is it the only grey wire out of the 2 plugs?
Should be pin 5 of the LH of the 2 plugs according to the green books, which is claims is black, but I'm sure I used a grey wire... To help you orientate, pin 2 of that plug is earth, i.e. brown. Your car currently uses pin 6 for power to the clock on a pink wire.
Ahh, ok, looking at p58/9 of the wiring green book (can be downloaded if you look further down the forum, very useful) the wire out the renix is grey, then turns black.
IvanAE86
Post by IvanAE86 »
Usually tacho's take their signal off the negative terminal of the ignition coil... cou can also wrap a pickup wire around the ignition cable as a coil, this will also pick up enough signal.
Jason B
Post by Jason B »
Chris is right, should be the grey wire out of the left-most plug on the renix supposing you are facing the renix from the side where the plugs are ;)
kaos
Post by kaos »
facing it from sat inside so smallest one is on the left the fuel gauge side biggest on the speedo side.
kaos
Post by kaos »
sorry to bring this one back up.
Just got my rev counter and a few other guages through the post and im looking at the wiring diagrams.
now as said the rev counter should go to the coil negative, would i be right in asuming the rev counter lead from the renix is connected to the coils negative? so this should all work correct once wired in.
