seat belt swapping
srtames
seat belt swapping
Post by srtames »
My drivers seat belt is begining to fray and my rear seat bels are like new . Are they the same length ie interchangeable before I start taking out the trim to swap them. Many thanks if you can advise
Steve
1989 340DL,1397
1979 CapriGL ,1593
Post by petefarrell360 »
Rear and front seat belts differ on the mountings, I'm pretty sure of that, as the front's mount onto the floor near the base of the door pillar, where as the rears mount below the rear shelf height within the rear quarters, so in theory will be different lengths too. Hope that helps.
kaos
Post by kaos »
and if its anything like mine one of them will be a seatbelt thats like the middle seatbelt. no extenable section just a length adjust. really annoys me.
Front and rears can not be swapped.
When seaking a replacment note that some cars were fitted with black belts and others with grey ones.
Be very careful when removing the plastic cover on the B pilar as if you pull on it it can snap in the middle. There is a slot cut in it for the belt to slid out from
Post by filthyjohn »
I have some front belts if you want them. Could either post them or drop them off with your engine if you don't need them immediately.
Cheers,
John.
